R5S before buying: can I use a 2.5G port as WAN?
Hi all,
Thinking about buying a NanoPi R5S but want to confirm one thing first.
I'd like to use one of the 2.5G ports as my WAN (my internet is faster than 1Gbps), and use the other 2.5G port plus the 1G port together as my LAN. Is this possible on the R5S, and does it work well in practice?
Mainly I want to know if there are any performance bottlenecks doing it this way — anything that would stop the 2.5G WAN from reaching full speed.
Thanks!
As you can see, there aren't very many knowledgeable people listening here :-(
Also, I recently discovered that the vanilla Linux kernel still doesn't support the 3 ethernet ports (it supports one, the "WAN" one), even though this device is now 4 years old, so buyer beware.
Yes, you can. I do it using FriendlyWrt.
I manually edited:
/etc/config/network
/etc/config/dhcp
/etc/config/firewall
eth0 1Gbps → 1Gbps Switch (10.0.0.0/24)
eth1 2.5Gbps → 2.5Gbps PC (10.0.1.0/24)
eth2 2.5Gbps → Internet
"does it work well in practice?" - that's an interesting question. My internet is 1000/100Mbps, so I'm not sure if you're going to get better throughput. The best I've seen is about 940Mbps which I read somewhere is a limitation of the device. But without faster internet, I can't test for certain.
In total there are 15 users online :: 0 registered, 0 hidden and 15 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 15 guests
