How to enable HW Encoder CEDAR in Nanopi Neo Core???
hello.
My board Nanopi Neo CORE
# uname -a
Linux NanoPi-NEO-Core 4.14.111 #126 SMP Mon Feb 22 17:04:18 CST 2021 armv7l armv7l armv7l GNU/Linux
I compiled and installed ffmpeg with Cedrus H264 and cedar_ve.ko
After that I see
# dmesg | grep cedar
[    4.982170] cedar_ve: loading out-of-tree module taints kernel.
[    4.988972] sunxi cedar version 0.1
I'm trying to edit and compile /boot/sun8i-h3-nanopi-neo-core.dts using https://github.com/uboborov/sunxi-cedar-mainline/blob/master/5.7/sun8i-h3-nanopi-neo-air.dts
First I change before soc
        reserved-memory {
                #address-cells = <0x01>;
                #size-cells = <0x01>;
                ranges;
                cma@43c00000 {
                        compatible = "shared-dma-pool";
                        reusable;
                        reg = < 0x57c00000 0x6000000 >;
                        linux,cma-default;
                        phandle = < 0x84 >;
and change in soc
                video-engine@01c0e000 {
                        compatible = "allwinner,sunxi-cedar-ve";
                        reg = < 0x1c0e000 0x1000 0x1c00000 0x10 0x1c20000 0x800 >;
                        memory-region = < 0x84 >;
                        syscon = < 0x15 >;
                        clocks = < 0x03 0x29 0x03 0x6c 0x03 0x61 >;
                        clock-names = "ahb", "mod", "ram";
                        resets = < 0x03 0x1a >;
                        interrupts = < 0x00 0x3a 0x04 >;
                        status = "okay";
after that I get
[    4.944911] cedar_ve: loading out-of-tree module taints kernel.
[    4.951697] sunxi cedar version 0.1
[    4.955629] [cedar]: install start!!!
[    4.959521] cedar_ve: cedar-ve the get irq is 55
[    4.964193] sunxi-cedar 1c0e000.video-engine: assigned reserved memory node cma@43c00000
[    4.972512] sunxi-cedar 1c0e000.video-engine: syscon failed...
[    4.998164] sunxi-cedar 1c0e000.video-engine: failed to get ahb clock
then I change and the board is no longer loaded
                syscon@1c00000 {
                        compatible = "allwinner,sun8i-h3-system-controller", "syscon";
                        reg = < 0x1c00000 0x1000 >;
                        #address-cells = < 0x01 >;
                        #size-cells = < 0x01 >;
                        ranges;
                        sram@1d00000 {
                            compatible = "mmio-sram";
                            reg = < 0x1d00000 0x80000 >;
                            ranges = < 0x00 0x1d00000 0x80000 >;
                            sram-section@0 {
                                compatible = "allwinner,sun8i-h3-sram-c1", "allwinner,sun4i-a10-sram-c1";
                                reg = < 0x00 0x80000 >;
Hello!
Do you make this?
What repo do you use for the cedrus?
I have used 3.4 kernel with update ubuntu 16 to ubuntu 18 and then to ubuntu 20.
Cedar is working. But very interesting your wey.
In total there are 23 users online :: 0 registered, 0 hidden and 23 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 23 guests
