NanoPi M1 no HDMI signal
I have tried running debian and armbian. I can log in via ssh but I have tried two different monitors with no success.
I have tried setting different resolutions on armbian with h3disp.
on Debian xrandr I get "Can't open display"
Monitor recognises the cable being plugged in but just displays "No Signal Detected" and shuts off.
I have seen some people having similar problems but one of them could boot into armbian which i can not.
Please try these two methods:
1. You can try connecting your board to a monitor with DVI interface with an HDMI to DVI cable
2. Please use a monitor which has an HDMI interface
If there are not useful , please connect a serial cable to read the kernel log information which prints hdmi i2c error.
thank you!
We didn't try you said the armbian, please try the FriendlyElec's ROM and we can check it if you can't success.
Thank you
Mindee
I have the same problem as Bob, but I've used the Debian OS of frendly arm.
The monitor is connected with HDMI-DVI cable.
Have you a idea?
Renato
Have you a idea?
Renato
Hi, Renato
Some HDMI-DVI converter is not compatible, it's better to connect a display device directly.
Thank you
-- Mindee
Hi Mindee,
thank you for your answer.
I am currently no monitor with hdmi input.
I have started the board now with Armbian and at the same time appears Armbian kernelboot information on the monitor. Shortly thereafter the monitor again no signal. Presumably when the desktopscreen is output.
Do you have another idea?
Possibly another screen resolution set?
geetings
Renato
renato wrote:
Hi Mindee,
geetings
Renato
I have no other suggestion for now, Generally it will take a long time to find and resolve such issue.
Thank you
-- Mindee
In total there are 12 users online :: 0 registered, 0 hidden and 12 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 12 guests
