change boot order , NanoPi R1
Hi
Is it possible to change the boot order on a NanoPi R1 , Ubuntu 16.04.7 LTS 4.14.111
Thank you so much
Best Regards
Héctor
Héctor wrote:
Hi
Thank you so much
Best Regards
Héctor
From where do you want to boot from?
https://forum.armbian.com/search/?q=boo ... &fromCSE=1
Hi
If there is a sdcard the NanoPi R1 boots of sdcard.
I want boot from emmc first.
I want this boot sequence.
1) emmc
2) sdcard
Best Regards
Héctor
Héctor wrote:
Hi
1) emmc
2) sdcard
Best Regards
Héctor
Click on link on a previous post and read few posts.
Hi
I have read this:
"With all Allwinner Socs, the SD card takes priority over eMMC ..."
It is right?
I want to boot NanoPi R1 from emmc always, even if there is sd card with eflasher.
I am not looking for a method to select boot from emmc by removing some bytes from the sd card (I am using this method and running fine) or with a dual boot installed to the sd card.
I want NanoPi R1 to boot only from emmc, changing something in emmc or some registry of NanoPi R1.
I can do it?
or
Can I enable / disable sdcard to prevent that NanoPi R1 boot from sdcard?
Thanks a lot
Sincerely
Hector
In total there are 9 users online :: 0 registered, 0 hidden and 9 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 9 guests
