Problems with Netflix
Good evening!
I installed Android on the eMMC flash memory of my NanoPC-T3, everything works fine, minus the Netflix app.
I can install the app, log in and even access the movie catalog, but when I click play in the movie, a 13001 error message appears and the app closes.
I have already accessed the Netflix site to solve the problem and the only solution is to clear the cache or reinstall the app, but it still does not work.
Does anyone have a solution to this problem?
Note: I already did tests running on Android from the SD card and it still does not work.
Thank you,
BarbaraValenzuela wrote:
Good evening!
Thank you,
Have you tried to install the app on any other device to ensure that if you are having the same issue on other devices too?
Good evening!
Thank you,
Check your time and date settings, make sure your time setting is correct (whether am or pm). That fixed it for me.
Netflix on my nook won`t work saying error 13001. what should i do to make it work again? it is working fine on my laptop
kossmoss wrote:
WhatsApp Aero APK
On the netflix forum, i got the same solution that is fixing the timing to automatic detection timezone & time, and updating the netflix app to the latest version. They are looking for the other solutions too.
Netflix on my nook won`t work saying error 13001. what should i do to make it work again? it is working fine on my laptop WhatsApp Aero APK
error 13001 error usually occurs due to compatibility issues or insufficient permission to run the app. Make sure you grant storage and network access to the Netflix in your Nook tablet. And also check if you have the latest version of netflix & is supported by the Nook.
I choose apkhihe to download my Netflix apk app for android, Netflix apk download at apkhihe is safe and free to use.
Was having the same issue on my old Android device. But after bought the new device it is working fine with it. I think you should try on another device. .
thomascook wrote:
Was having the same issue on my old Android device. But after bought the new device it is working fine with it. I think you should try on another device. geometry dash world
I tried on another device. I also changed the time zone according to the instructions but this error still exists.
thomascook wrote:
Was having the same issue on my old Android device. But after bought the new device it is working fine with it. I think you should try on another device.nulls brawl
Trying it on another device is not a reliable solution. What if someone doesn't have another device and facing the same issue?
Resetting the device is just a suggestion. Maybe it will reset all the settings to its original and any changes made by you that caused this issue will be reverted. It can solve the solution if related to the device. Otherwise, need to contact the Netflix support.
It sounds like a DRM compatibility issue, as Netflix requires certain certifications to stream content. Since you're running Android on a NanoPC-T3, it may not have Widevine L1 support, which is needed for Netflix playback. You can check this using the DRM Info app from the Play Store. If it's not supported, you might be limited to lower-quality streams or need a workaround like using an older version of Netflix .Hope this helps!
​Experiencing the same Netflix error 13001 on my NanoPC-T3. Tried clearing cache and reinstalling, but no luck. Checked time and date settings as suggested, but the issue persists. Any other ideas?​
trossard wrote:
.​Experiencing the same Netflix error 13001 on my NanoPC-T3. Tried clearing cache and reinstalling, but no luck. Checked time and date settings as suggested, but the issue persists. Any other ideas?​
Netflix requires Widevine L1 or L3 DRM for playback. Many custom or Linux-based builds on NanoPCs lack official DRM support, which leads to errors like 13001. You should check it first.
I ran into the same Netflix 13001 error before. Clearing cache or reinstalling never fixed it for me either. What worked was updating to a newer Android build and making sure Widevine DRM was properly supported — Netflix needs that to play. If your NanoPC-T3 build doesn’t support Widevine L1, the app usually crashes when trying to stream. You might want to try an updated firmware or a custom ROM that has DRM support built in.
In total there are 13 users online :: 0 registered, 0 hidden and 13 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 13 guests
