BT won't start on Nanopi M4 Android 8.1
With prebuilt Android 8.1 on nanopi m4, Bluetooth won't enable. Popup says BT failed continuously.
Do you have any work around?
Can you hook up to the serial port and capture the logcat output? Type in logcat and it will output the debug information. There should be an exception recorded from the BT software and that will help to track down the issue.
Same thing here, with a NEO4. Will try to get a capture.
In total there are 17 users online :: 0 registered, 0 hidden and 17 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 17 guests
