Problem with eMMC Adapter
I've tried the following combinations:
eMMC => eMMC Adapter => MicroSD to SD Adapter => USB Adapter
Tried different SD adapters but still the same problem whereby Windows doesn't see the eMMC whatsoever, or, sees the drive is there but intermittently keeps disconnecting/reconnecting.
Anyone else having issues?
Don't you have a microsd reader? I think you may not use an microsd to sd adapter. It's like that with an Odroid eMMC.
You probably wan't see any drives added when it works. Windows can't read these formats.
Use sd-formatter, that should find it.
Most images you can install to eMMC from sd-cards.
Greetings.
How do you install to the eMMC from the SD ?
Is this documented ?
I have the MicroSD to eMMC adapter, no Windows, only Linux and Mac OS
In total there are 21 users online :: 0 registered, 0 hidden and 21 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 21 guests
