Casing or Housing for M4 with heatsink
Do you have casing or housing for M4 with heatsink?
Or are there compatible case for M4 with heatsink?
Thank you
KR
I have the same with acrylic case preference. Any pointer?
Hi there
I found and printed this one: https://www.thingiverse.com/thing:3313324
Nice and fitted perfectly
I found the top really flimsy but does the job ok...
I'm using the official RPI case. i used an exacto knife to cut out the bottom, soft plastic made it easy. the usbc hole needed to be enlarged a bit but no big deal. Remembet to cut off the fin between the usb ports to leave room for the uart. I chose this mainly for the fact that the top and side plates are easily removable and could be swapped for custom 3d parts eventually.
In total there are 8 users online :: 0 registered, 0 hidden and 8 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 8 guests
