NanoPI neo2 nas dock
i purchased a kit with the neo2 and nas dock, i have installed the nanopi-neo2_debian-nas-jessie_4.16.0_20180420.img and it boots fine but it will not detect any HD's. i have tried 2 SSD's and 1 2.5" WD hd and nothing shows for hard drives. Is there a bootloader image i need to update to support the nas dock? i would assume that with the kit it was already installed.
with this image it should normally detect the HDD as /dev/sda
Iam using 2 Neo2 with the silver-NAS-case under armbian mainline (debian stretch) and installed there a samba-server:
https://dl.armbian.com/nanopineo2/archi ... 4.14.14.7z
Did you buy the 12V Power Supply or did you have it on your own?
My powersupply has 12V/2A (from a old DSL-Router) and is working Ok 24/7
On mine I got a normal 2.5" 320GB HDD inside the case
Or did you buy the "Nas dock" only without case? because the NAS-Dock-only (JMS20329 = USB2.0)
http://www.friendlyarm.com/index.php?ro ... egory=true
has a different HDD-Controller Chipset than the NAS-Case with a NAS-Dock inside has JMS567 (USB 3.0 Controller connected to USB 2.0)
Maybe the image you downloaded does support only the newer JMS567?
I ordered the complete package including the power supply, i look at the board and the chipset model is JMS567 so i am pretty sure the image supports it. I will try a 12V 4A power supply and see if that works.
i have tried 3 different drive 2 SSD's and 1 WD Black 2.5" with a 12 v 5A power supply still nothing, it does detect the usb hub from the nas board but no hd's show up here is dmesg log
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.16.0-rc6 (root@wwd) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #19 SMP Fri Apr 20 14:25:42 CST 2018
[ 0.000000] Machine model: FriendlyElec NanoPi-NEO2
[ 0.000000] cma: Reserved 64 MiB at 0x000000005c000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] random: fast init done
[ 0.000000] percpu: Embedded 23 pages/cpu @ (ptrval) s54680 r8192 d31336 u94208
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129024
[ 0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait fsck.repair=yes panic=10 fbcon=map:0
[ 0.000000] log_buf_len individual max cpu contribution: 4096 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 12288 bytes
[ 0.000000] log_buf_len min size: 16384 bytes
[ 0.000000] log_buf_len: 32768 bytes
[ 0.000000] early log buf free: 14812(90%)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] Memory: 421840K/524288K available (9086K kernel code, 696K rwdata, 3132K rodata, 512K init, 412K bss, 36912K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000153] Console: colour dummy device 80x25
[ 0.000178] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.000188] pid_max: default: 32768 minimum: 301
[ 0.000264] Security Framework initialized
[ 0.000274] AppArmor: AppArmor disabled by boot time parameter
[ 0.000318] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.000328] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.001455] ASID allocator initialised with 32768 entries
[ 0.001514] Hierarchical SRCU implementation.
[ 0.001980] smp: Bringing up secondary CPUs ...
[ 0.003045] Detected VIPT I-cache on CPU1
[ 0.003102] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.003775] Detected VIPT I-cache on CPU2
[ 0.003802] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.004476] Detected VIPT I-cache on CPU3
[ 0.004500] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.004554] smp: Brought up 1 node, 4 CPUs
[ 0.004572] SMP: Total of 4 processors activated.
[ 0.004579] CPU features: detected feature: 32-bit EL0 Support
[ 0.004584] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.007585] CPU: All CPU(s) started at EL2
[ 0.007601] alternatives: patching kernel code
[ 0.008435] devtmpfs: initialized
[ 0.012828] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.012848] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.014912] pinctrl core: initialized pinctrl subsystem
[ 0.015724] NET: Registered protocol family 16
[ 0.016182] audit: initializing netlink subsys (disabled)
[ 0.016340] audit: type=2000 audit(0.016:1): state=initialized audit_enabled=0 res=1
[ 0.016693] cpuidle: using governor menu
[ 0.016894] vdso: 2 pages (1 code @ 00000000742ad9a8, 1 data @ 0000000046abd2ca)
[ 0.016909] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.017762] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.017816] Serial: AMBA PL011 UART driver
[ 0.028560] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.028802] cryptd: max_cpu_qlen set to 1000
[ 0.029285] reg-fixed-voltage gmac-3v3: could not find pctldev for node /soc/pinctrl@1c20800/gmac_power_pin@0, deferring probe
[ 0.029628] gpio-regulator gpio-regulator: could not find pctldev for node /soc/pinctrl@1f02c00/regulator_pins@0, deferring probe
[ 0.029945] SCSI subsystem initialized
[ 0.030091] usbcore: registered new interface driver usbfs
[ 0.030121] usbcore: registered new interface driver hub
[ 0.030163] usbcore: registered new device driver usb
[ 0.030332] media: Linux media interface: v0.10
[ 0.030355] Linux video capture interface: v2.00
[ 0.030412] pps_core: LinuxPPS API ver. 1 registered
[ 0.030417] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.030431] PTP clock support registered
[ 0.030663] Advanced Linux Sound Architecture Driver Initialized.
[ 0.031610] clocksource: Switched to clocksource arch_sys_counter
[ 0.031856] VFS: Disk quotas dquot_6.6.0
[ 0.031911] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.032040] FS-Cache: Loaded
[ 0.032241] CacheFiles: Loaded
[ 0.037140] NET: Registered protocol family 2
[ 0.037600] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes)
[ 0.037623] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.037665] TCP bind hash table entries: 4096 (order: 4, 65536 bytes)
[ 0.037757] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.037850] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.037868] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.038029] NET: Registered protocol family 1
[ 0.038411] RPC: Registered named UNIX socket transport module.
[ 0.038416] RPC: Registered udp transport module.
[ 0.038421] RPC: Registered tcp transport module.
[ 0.038425] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.038924] Unpacking initramfs...
[ 0.234349] Initramfs unpacking failed: junk in compressed archive
[ 0.238076] Freeing initrd memory: 5120K
[ 0.242226] Initialise system trusted keyrings
[ 0.242348] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 0.247801] FS-Cache: Netfs 'nfs' registered for caching
[ 0.248212] NFS: Registering the id_resolver key type
[ 0.248240] Key type id_resolver registered
[ 0.248245] Key type id_legacy registered
[ 0.248259] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.248265] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.253250] NET: Registered protocol family 38
[ 0.253330] Key type asymmetric registered
[ 0.253337] Asymmetric key parser 'x509' registered
[ 0.253530] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.253628] io scheduler noop registered
[ 0.253633] io scheduler deadline registered
[ 0.253801] io scheduler cfq registered (default)
[ 0.253807] io scheduler mq-deadline registered
[ 0.253812] io scheduler kyber registered
[ 0.254299] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO, pinctrl may not init
[ 0.255894] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[ 0.258366] sun50i-h5-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.263456] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.264436] console [ttyS0] disabled
[ 0.285114] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 29, base_baud = 1500000) is a U6_16550A
[ 0.980712] console [ttyS0] enabled
[ 1.007034] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 30, base_baud = 1500000) is a U6_16550A
[ 1.038605] 1c28c00.serial: ttyS3 at MMIO 0x1c28c00 (irq = 31, base_baud = 1500000) is a U6_16550A
[ 1.080782] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_ops)
[ 1.088279] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[ 1.096111] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_ops)
[ 1.104845] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[ 1.114591] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.122252] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops)
[ 1.129647] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.136256] [drm] No driver support for vblank timestamp query.
[ 1.142210] [drm] Cannot find any crtc or sizes, assume HDMI: 1920X1080
[ 1.184185] Console: switching to colour frame buffer device 240x67
[ 1.219132] sun4i-drm display-engine: fb0: frame buffer device
[ 1.225373] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.234083] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.244436] loop: module loaded
[ 1.249177] libphy: Fixed MDIO Bus: probed
[ 1.253908] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 1.260170] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.266695] ehci-platform: EHCI generic platform driver
[ 1.272039] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 1.277627] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 1.285735] ehci-platform 1c1a000.usb: irq 10, io mem 0x01c1a000
[ 1.307617] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 1.313894] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.320685] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.327903] usb usb1: Product: EHCI Host Controller
[ 1.332780] usb usb1: Manufacturer: Linux 4.16.0-rc6 ehci_hcd
[ 1.338523] usb usb1: SerialNumber: 1c1a000.usb
[ 1.343461] hub 1-0:1.0: USB hub found
[ 1.347249] hub 1-0:1.0: 1 port detected
[ 1.351734] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.357929] ohci-platform: OHCI generic platform driver
[ 1.363306] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.369929] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.377858] ohci-platform 1c1a400.usb: irq 11, io mem 0x01c1a400
[ 1.447766] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.454555] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.461775] usb usb2: Product: Generic Platform OHCI controller
[ 1.467692] usb usb2: Manufacturer: Linux 4.16.0-rc6 ohci_hcd
[ 1.473435] usb usb2: SerialNumber: 1c1a400.usb
[ 1.478334] hub 2-0:1.0: USB hub found
[ 1.482121] hub 2-0:1.0: 1 port detected
[ 1.486612] usbcore: registered new interface driver uas
[ 1.491987] usbcore: registered new interface driver usb-storage
[ 1.498460] mousedev: PS/2 mouse device common for all mice
[ 1.504279] ads7846 spi0.1: spi0.1 supply vcc not found, using dummy regulator
[ 1.511799] ads7846 spi0.1: touchscreen, irq 144
[ 1.516819] input: ADS7846 Touchscreen as /devices/platform/soc/1c68000.spi/spi_master/spi0/spi0.1/input/input0
[ 1.527352] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.534145] sun6i-rtc 1f00000.rtc: RTC enabled
[ 1.538640] i2c /dev entries driver
[ 1.543797] thermal thermal_zone0: failed to read out thermal zone (-16)
[ 1.550822] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.559140] sdhci: Secure Digital Host Controller Interface driver
[ 1.565333] sdhci: Copyright(c) Pierre Ossman
[ 1.569716] Synopsys Designware Multimedia Card Interface Driver
[ 1.576783] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[ 1.606597] sunxi-mmc 1c0f000.mmc: base:0x0000000001fb12f2 irq:8
[ 1.612811] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.619108] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.625298] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.630871] usbcore: registered new interface driver usbhid
[ 1.636442] usbhid: USB HID core driver
[ 1.640348] fbtft_of_value: buswidth = 8
[ 1.644276] fbtft_of_value: debug = 0
[ 1.647939] fbtft_of_value: rotate = 90
[ 1.651775] fbtft_of_value: fps = 33
[ 1.805496] graphics fb1: fb_st7789v frame buffer, 320x240, 150 KiB video memory, 4 KiB buffer memory, fps=35, spi0.0 at 50 MHz
[ 1.827566] sun4i-codec 1c22c00.codec: ASoC: Failed to create component debugfs directory
[ 1.837123] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.839811] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.846153] NET: Registered protocol family 10
[ 1.858673] mmc0: new high speed SDHC card at address aaaa
[ 1.865816] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[ 1.869357] Segment Routing with IPv6
[ 1.874015] NET: Registered protocol family 17
[ 1.874686] mmcblk0: p1 p2
[ 1.878781] 9pnet: Installing 9P2000 support
[ 1.885578] Key type dns_resolver registered
[ 1.890352] registered taskstats version 1
[ 1.894461] Loading compiled-in X.509 certificates
[ 1.904780] Key type encrypted registered
[ 1.915643] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 2.027678] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 2.033341] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 2.040560] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 2.046210] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 2.053427] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 2.058390] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 2.065250] libphy: stmmac: probed
[ 2.069137] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[ 2.075281] libphy: mdio_mux: probed
[ 2.078870] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[ 2.085222] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[ 2.094492] libphy: mdio_mux: probed
[ 2.098105] dwmac-sun8i 1c30000.ethernet: Switch mux to external PHY
[ 2.108072] ehci-platform 1c1b000.usb: EHCI Host Controller
[ 2.113674] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[ 2.121784] ehci-platform 1c1b000.usb: irq 12, io mem 0x01c1b000
[ 2.143618] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[ 2.149852] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.156641] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.163857] usb usb3: Product: EHCI Host Controller
[ 2.168733] usb usb3: Manufacturer: Linux 4.16.0-rc6 ehci_hcd
[ 2.174475] usb usb3: SerialNumber: 1c1b000.usb
[ 2.179422] hub 3-0:1.0: USB hub found
[ 2.183198] hub 3-0:1.0: 1 port detected
[ 2.187741] ehci-platform 1c1c000.usb: EHCI Host Controller
[ 2.193327] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
[ 2.201293] ehci-platform 1c1c000.usb: irq 14, io mem 0x01c1c000
[ 2.219615] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[ 2.225812] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.232601] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.239818] usb usb4: Product: EHCI Host Controller
[ 2.244696] usb usb4: Manufacturer: Linux 4.16.0-rc6 ehci_hcd
[ 2.250438] usb usb4: SerialNumber: 1c1c000.usb
[ 2.255314] hub 4-0:1.0: USB hub found
[ 2.259086] hub 4-0:1.0: 1 port detected
[ 2.263577] ehci-platform 1c1d000.usb: EHCI Host Controller
[ 2.269164] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
[ 2.277130] ehci-platform 1c1d000.usb: irq 16, io mem 0x01c1d000
[ 2.295613] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[ 2.301810] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.308598] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.315815] usb usb5: Product: EHCI Host Controller
[ 2.320693] usb usb5: Manufacturer: Linux 4.16.0-rc6 ehci_hcd
[ 2.326435] usb usb5: SerialNumber: 1c1d000.usb
[ 2.331284] hub 5-0:1.0: USB hub found
[ 2.335058] hub 5-0:1.0: 1 port detected
[ 2.339519] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[ 2.346143] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[ 2.354058] ohci-platform 1c1b400.usb: irq 13, io mem 0x01c1b400
[ 2.423736] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.430524] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.437741] usb usb6: Product: Generic Platform OHCI controller
[ 2.443660] usb usb6: Manufacturer: Linux 4.16.0-rc6 ohci_hcd
[ 2.449403] usb usb6: SerialNumber: 1c1b400.usb
[ 2.454291] hub 6-0:1.0: USB hub found
[ 2.458066] hub 6-0:1.0: 1 port detected
[ 2.462538] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[ 2.469162] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[ 2.477072] ohci-platform 1c1c400.usb: irq 15, io mem 0x01c1c400
[ 2.543739] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.550527] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.557745] usb usb7: Product: Generic Platform OHCI controller
[ 2.563663] usb usb7: Manufacturer: Linux 4.16.0-rc6 ohci_hcd
[ 2.569405] usb usb7: SerialNumber: 1c1c400.usb
[ 2.574259] hub 7-0:1.0: USB hub found
[ 2.578035] hub 7-0:1.0: 1 port detected
[ 2.582491] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[ 2.589118] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[ 2.597054] ohci-platform 1c1d400.usb: irq 17, io mem 0x01c1d400
[ 2.663730] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.670518] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.677736] usb usb8: Product: Generic Platform OHCI controller
[ 2.683654] usb usb8: Manufacturer: Linux 4.16.0-rc6 ohci_hcd
[ 2.689397] usb usb8: SerialNumber: 1c1d400.usb
[ 2.694269] hub 8-0:1.0: USB hub found
[ 2.698049] hub 8-0:1.0: 1 port detected
[ 2.702540] usb_phy_generic usb_phy_generic.3.auto: usb_phy_generic.3.auto supply vcc not found, using dummy regulator
[ 2.713524] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
[ 2.719273] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9
[ 2.727226] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.734017] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.741237] usb usb9: Product: MUSB HDRC host driver
[ 2.746202] usb usb9: Manufacturer: Linux 4.16.0-rc6 musb-hcd
[ 2.751946] usb usb9: SerialNumber: musb-hdrc.4.auto
[ 2.757227] hub 9-0:1.0: USB hub found
[ 2.761002] hub 9-0:1.0: 1 port detected
[ 2.767873] input: r-gpio-keys as /devices/platform/r-gpio-keys/input/input1
[ 2.775252] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.792121] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.798826] usb0-vbus: disabling
[ 2.802073] ALSA device list:
[ 2.805053] #0: Dummy 1
[ 2.807681] #1: Loopback 1
[ 2.810559] #2: H3 Audio Codec
[ 2.814192] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.814560] Freeing unused kernel memory: 512K
[ 2.822824] cfg80211: failed to load regulatory.db
Loading, please wait...
starting version 229
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... done.
Begin: Will now check root file system ... fsck from util-linux 2.27.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p2] fsck.ext4 -y -C0 /dev/mmcblk0p2
e2fsck 1.42.13 (17-May-2015)
rootfs: clean, 57068/1896000 files, 624136/7760000 blocks
done.
[ 3.477578] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.501578] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
[ 3.849962] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 3.863476] systemd[1]: Detected architecture 'arm64'.
Welcome to Debian GNU/Linux 8 (jessie)!
[ 3.902878] systemd[1]: Set hostname to <FriendlyELEC>.
[ 4.220972] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 4.237532] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 4.245548] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.253153] systemd[1]: Expecting device dev-ttyS0.device...
[ 4.268476] systemd[1]: Starting Remote File Systems (Pre).
[ OK ] Reached target Remote File Systems (Pre).
[ 4.287688] systemd[1]: Reached target Remote File Systems (Pre).
[ 4.294777] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ OK ] Set up automount Arbitrary Executable File Formats F...utomount Point.
Expecting device dev-mmcblk0p1.device...
[ OK ] Created slice Root Slice.
[ OK ] Created slice User and Session Slice.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on LVM2 metadata daemon socket.
[ OK ] Listening on Device-mapper event daemon FIFOs.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on Journal Socket.
[ OK ] Created slice System Slice.
[ OK ] Created slice system-getty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Increase datagram queue length...
Starting Nameserver information manager...
Mounting Huge Pages File System...
Mounting POSIX Message Queue File System...
Starting Create list of required static device nodes...rrent kernel...
Mounting Debug File System...
Starting Load Kernel Modules...
Starting udev Coldplug all Devices...
[ OK ] Reached target Slices.
[ OK ] Mounted Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Huge Pages File System.
[ OK ] Started Increase datagram queue length.
[ 4.730343] fuse init (API version 7.26)
[ OK ] Started Create list of required static device nodes ...current kernel.
[ 4.758942] Mass Storage Function, version: 2009/09/11
[ 4.764136] LUN: removable file: (no medium)
[ 4.768752] LUN: file: /dev/mmcblk0p1
[ 4.772445] Number of LUNs=1
[ OK ] [ 4.776051] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
Started Nameserver information manager.
[ 4.784320] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 4.794904] g_mass_storage gadget: g_mass_storage ready
[ OK ] Started Load Kernel Modules.
[ OK ] Started udev Coldplug all Devices.
Starting udev Wait for Complete Device Initialization...
Mounting FUSE Control File System...
Mounting Configuration File System...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Listening on Syslog Socket.
Starting Journal Service...
[ OK ] Started Journal Service.
[ OK ] Mounted Configuration File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ 5.126756] systemd-udevd[321]: starting version 215
[ OK ] Started udev Kernel Device Manager.
Starting LSB: MD array assembly...
Starting LSB: Set preliminary keymap...
Starting LSB: Tune IDE hard disks...
[ OK ] Started LSB: MD array assembly.
[ OK ] Started LSB: Tune IDE hard disks.
[ OK ] Reached target Sound Card.
[ OK ] Found device /dev/ttyS0.
[ 5.493198] rtc-ds1307 0-0068: registered as rtc1
[ 5.510432] asoc-simple-card soc:sound: i2s-hifi <-> 1c22800.i2s mapping ok
[ OK ] Found device /dev/mmcblk0p1.
[ OK ] Started udev Wait for Complete Device Initialization.
[ OK ] Started LSB: Set preliminary keymap.
Starting Remount Root and Kernel File Systems...
Starting Activation of LVM2 logical volumes...
Starting Copy rules generated while the root was ro...
[ OK ] Created slice system-ifup.slice.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Copy rules generated while the root was ro.
Activating swap /mnt/512MB.swap...
Starting Initial Check File System Quotas...
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems (Pre).
Mounting /tmp...
Mounting /boot...
[ OK ] Mounted /tmp.
[ 5.889021] Adding 524284k swap on /mnt/512MB.swap. Priority:-2 extents:5 across:1091616k SS
[ OK ] Activated swap /mnt/512MB.swap.
[ OK ] Started Activation of LVM2 logical volumes.
[ 5.934254] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ OK ] Started Initial Check File System Quotas.
[ OK ] Started Load/Save Random Seed.
[ OK ] Mounted /boot.
[ OK ] Reached target Encrypted Volumes.
[ OK ] Reached target Swap.
Starting Monitoring of LVM2 mirrors, snapshots etc. ...ress polling...
[ OK ] Started Monitoring of LVM2 mirrors, snapshots etc. u...ogress polling.
[ OK ] Reached target Local File Systems.
Starting Cleanup monit state file...
Starting Cleanup PHP session files...
Starting Create Volatile Files and Directories...
Starting LSB: Raise network interfaces....
[ OK ] Reached target Remote File Systems.
Starting Trigger Flushing of Journal to Persistent Storage...
Starting LSB: Prepare console...
[ OK ] Started Cleanup monit state file.
[ OK ] Started Cleanup PHP session files.
[ OK ] Started Create Volatile Files and Directories.
[ 6.413603] systemd-journald[313]: Received request to flush runtime journal from PID 1
[ OK ] Started Trigger Flushing of Journal to Persistent Storage.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started LSB: Prepare console.
[ OK ] Started Update UTMP about System Boot/Shutdown.
Starting LSB: Set console font and keymap...
[ 6.722462] RTL8211E Gigabit Ethernet 0.2:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=0.2:00, irq=POLL)
[ 6.741069] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[ 6.741078] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[ OK ] Started LSB: Raise network interfaces..
Starting ifup for eth0...
[ OK ] Started ifup for eth0.
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
Starting LSB: RPC portmapper replacement...
[ OK ] Started LSB: Set console font and keymap.
[ OK ] Started LSB: RPC portmapper replacement.
[ OK ] Reached target RPC Port Mapper.
Starting LSB: NFS support files common to client and server...
[ OK ] Started LSB: NFS support files common to client and server.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Timers.
[ OK ] Listening on ACPID Listen Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Paths.
[ OK ] Reached target Basic System.
Starting Run anacron jobs...
[ OK ] Started Run anacron jobs.
Starting brcm_patchram_plus...
Starting Regular background program processing daemon...
[ OK ] Started Regular background program processing daemon.
Starting A high performance web server and a reverse proxy server...
Starting The OpenMediaVault engine daemon that proce... RPC request...
Starting The PHP FastCGI Process Manager...
Starting RPC Remote Quota Server...
Starting OpenBSD Secure Shell server...
Starting /etc/rc.local Compatibility...
Starting Login Service...
Starting LSB: Start busybox udhcpd at boot time...
Starting LSB: clean_ip_info...
Starting LSB: SNMP agents...
Starting LSB: select system audio output at first boot...
Starting LSB: start Samba daemons for the AD DC...
Starting LSB: Starts ProFTPD daemon...
Starting LSB: Start NTP daemon...
Starting LSB: start Samba NetBIOS nameserver (nmbd)...
Starting LSB: Kernel NFS server support...
Starting LSB: service and resource monitoring daemon...
Starting LSB: Load kernel modules needed to enable cpufreq scaling...
Starting LSB: Advanced IEEE 802.11 management daemon...
Starting Avahi mDNS/DNS-SD Stack...
Starting D-Bus System Message Bus...
[ OK ] Started D-Bus System Message Bus.
[ 8.022663] random: crng init done
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting System Logging Service...
Starting ACPI event daemon...
[ OK ] Started ACPI event daemon.
Starting Permit User Sessions...
[ OK ] Started brcm_patchram_plus.
[ OK ] Started RPC Remote Quota Server.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started LSB: Start busybox udhcpd at boot time.
[ OK ] Started LSB: select system audio output at first boot.
[ OK ] Started LSB: Starts ProFTPD daemon.
[ OK ] Started LSB: Start NTP daemon.
[ OK ] Started LSB: Kernel NFS server support.
[ OK ] Started LSB: service and resource monitoring daemon.
[ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling.
[ OK ] Started LSB: Advanced IEEE 802.11 management daemon.
[ OK ] Started Permit User Sessions.
[ OK ] Started System Logging Service.
Mounting Arbitrary Executable File Formats File System...
Starting LSB: set CPUFreq kernel parameters...
Starting Getty on tty2...
[ OK ] Started Getty on tty2.
Starting Serial Getty on ttyS0...
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Reached target Login Prompts.
[ OK ] Mounted Arbitrary Executable File Formats File System.
[ OK ] Started Login Service.
[ OK ] Started LSB: set CPUFreq kernel parameters.
[ OK ] Started LSB: SNMP agents.
[ OK ] Started A high performance web server and a reverse proxy server.
[ OK ] Started The OpenMediaVault engine daemon that proces...he RPC request.
[ OK ] Started The PHP FastCGI Process Manager.
[ OK ] Started LSB: clean_ip_info.
[ OK ] Started LSB: start Samba daemons for the AD DC.
[ OK ] Started LSB: start Samba NetBIOS nameserver (nmbd).
Starting LSB: start Samba SMB/CIFS daemon (smbd)...
[ OK ] Started LSB: start Samba SMB/CIFS daemon (smbd).
[ OK ] Reached target Multi-User System.
Starting Beep after system start...
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
[ OK ] Started Beep after system start.
openmediavault 3.0.99 (Erasmus) FriendlyELEC ttyS0
Copyright (C) 2009-2018 by Volker Theile. All rights reserved.
To manage the system visit the openmediavault web control panel:
No network interface(s) available
By default the web control panel administrator account has the
username 'admin' and password 'openmediavault'.
It is recommended that you change the password for this account
within the web control panel or using the 'omv-firstaid' CLI
command.
For more information regarding this appliance, please visit the
web site: http://www.openmediavault.org
FriendlyELEC login:
Did you ordered a soldered Neo2 oder did you solder the pins youself?
If you didnt see more with the 12V/4A (you didnt need 4A :) ) the please try armbian first before searching too long with the friendlyarm-image :)
pins where soldered from factory, yeah i guess i will try armbian
Booted with armbian, same issue no HD detected. I am at a loss here.
Mine does show with armbian:
root@nanopineo23:~# dmesg|grep -i sd
[ 1.587369] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.716918] sdhci: Secure Digital Host Controller Interface driver
[ 1.716921] sdhci: Copyright(c) Pierre Ossman
[ 1.757180] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.823523] mmc0: new high speed SDHC card at address aaaa
[ 2.466034] usb 4-1: Manufacturer: JMicron
[ 2.474497] scsi 0:0:0:0: Direct-Access JMicron Tech 0227 PQ: 0 ANSI: 6
[ 2.476181] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.477244] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 2.477252] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.477608] sd 0:0:0:0: [sda] Write Protect is off
[ 2.477616] sd 0:0:0:0: [sda] Mode Sense: 5f 00 00 08
[ 2.478365] sd 0:0:0:0: [sda] Disabling FUA
[ 2.478377] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.273661] sda: sda1
[ 5.277773] sd 0:0:0:0: [sda] Attached SCSI disk
[ 8.685999] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
root@nanopineo23:~# uname -a
Linux nanopineo23 4.14.37-sunxi64 #45 SMP Thu Apr 26 19:19:03 CEST 2018 aarch64 GNU/Linux
But no module on lsmod for the JMS567 - but it should be shown at the command lsusb as jmicro:
root@nanopineo23:~# lsusb
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp.
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
In total there are 30 users online :: 0 registered, 0 hidden and 30 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 30 guests
