Any updates on CVBS video output ?
Hello Guys.
I need the CVBS output for a project with 4.11 kernel. By default it dosen`t work. Is there any way to enable it in FriendlyCore or Armbian ? It seems that orange pi zero has activated this option.
thanks.
meisam wrote:
Hello Guys.
thanks.
You mean this: https://imgur.com/mFlD02q
I saw it on IRC, but I haven't tried by myself yet. It is definitely not present in 4.11.y
igorp wrote:
meisam wrote:
Hello Guys.
thanks.
in the Armbian , (currently 4.14.y) i see some config for the output graphic in "setenv ..." .
is it possible to change it to the CVBS port ?
meisam wrote:
igorp wrote:
meisam wrote:
Hello Guys.
thanks.
No, it is not on this level yet. You need to add certain patches to the source code and recompile. I don't have the option to test this function. When / if it reaches armbian, this will be accessible via armbian-config -> system -> hardware
I'm really desperate to get CVBS working.
I've modified sun8i-h3.dts file following advice on https://github.com/stevenj/h3-tve/blob/ ... e-11.patch.
Any help with this would be really appreciated.
Kind regards
Kind regards
As you can see there are changes also in the video driver code and if you didn't apply those is simply can't work. IMO you need them too and kernel recompilation is needed.
But since there are many changes to the video driver lately, this might not just work ... and it is also possible that developers will add CVBS in by default. In a few months.
Hello Igor,
thanks for your response.
I'll try with another device, maybe a Raspberry Pi.
Kind regards
In total there are 7 users online :: 0 registered, 0 hidden and 7 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 7 guests
