Android Reboot Loop with 7" LCD attached
I'm having trouble flashing a working Android image on my Nanopi2 with 7"LCD
I flashed the newest image on GDrive using dd. When I boot the nanopi2 I see the friendlyarm logo flash on and off on my 7" LCD. Watching over serial I don't see a crash in the kernel, I just see it suddenly go back to the uboot prompt then start booting the kernel again.
Answering my own question incase it helps others.
The problem was that the provided power supply isn't sufficient to power the LCD and board at the same time. I replaced with my RPi3 power supply and all is well.
A stable 5V/2A power supply is a must.
I would just expect FriendlyArm to have included one with the nanopi2/lcd combo I purchased. The one I received wasn't. Just an FYI to anyone else who purchases the NanoPi2/LCD/Power supply package.
hi all,
i have bought NanoPi2 and NanoPi2 Fire
i'm using this PSU power supply : http://www.friendlyarm.com/index.php?route=product/product&path=73&product_id=127
for NanoPi2 :
if i plug in to micro USB socket, reboot loop is happened
but if i plug in to power pins from GPIO (VCC & GND), it's boot normally and running well.
for NanoPi2 Fire:
if i plug in to micro USB socket, just once boot shown FriendlyARM logo only and then the LCD is blank and 2 LED on the board is off.
same case for plug in to power pins.
i'm using this image for both board :s5p4418-android-sd4g-20160629.img
any solution?
sorry for my English :)
thanks
Hello.
I have the same problem with a nanopi2 fire. I am using a power supply with 3 A of maximum output current. In attachment you can find the boot log. Can you check it ?
I flashed the newest image on GDrive using dd. When I boot the nanopi2 I see the friendlyarm logo flash on and off on my 7" LCD. .
A stable 5V/2A power supply is a must. ;) ;)
In total there are 5 users online :: 0 registered, 0 hidden and 5 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 5 guests
