Core2 GPIO2/3 Pin Description incorrect on wiki
http://wiki.friendlyarm.com/wiki/index. ... re2#Layout
The tables describing the pins for the GPIO2 and GPIO3 headers are incorrect in the wiki. Specifically the pins in the left column for the GPIO2 and GPIO3 tables should be odd numbers 1, 3, 5, 7, ... both tables have duplicate entires for even numbered pins (for example pin 4).
The USB-DM2 entry in the GPIO3 table also appears incorrect. I believe it should be USB-DM3 and the description should be different, probably "USB3 DM Signal".
thanks for your correction. We have corrected our mistakes.
In total there are 17 users online :: 0 registered, 0 hidden and 17 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 17 guests
