Can you create a guide to configure OTG ethernet mode
I'd like to use the USB-port as a linux OTG gadget under debian - can you create a guide and provide necessary files similar to ADB? I can see the drivers being loaded from usbcore during boot but there is no module to load with modprobe that sticks.
The idea is to connect the USB-C to windows laptop and use ethernet over the cable (RNDIS / g_ether for raspberry pi) so that the NanoPi Zero2 becomes a VPN device
For anyones interested I did this myself - after too much digging into linux configfs it led me to the /usr/bin/usbdevice (and -wrapper file).
Below should be enough to get the NanoPi Zero2 working as an OTG RNDIS ethernet adapter over the USB-C port, I ended up creating these files to get everything up and running from bootup:
/etc/usbdevice.d/usbrndis.sh (with +x permission)
#!/bin/sh
# Place this file into directory (create if not existing) /etc/usbdevice.d/
USB_FUNCS='rndis'
/lib/systemd/system/usbrndis.service
followed by: systemctl enable usbrndis
# Service file for USB RNDIS
# - place this file into /lib/systemd/system
# - run: systemctl enable usbrndis
[Unit]
Description=Manage USB RNDIS systemd environment
DefaultDependencies=no
Before=network.target
[Service]
Type=simple
ExecStart=/usr/bin/usbdevice start
ExecStop=/usr/bin/usbdevice stop
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
Restart system and check dmesg for usb0 messages, should see random macs assigned:
dmesg | grep usb0
Finally to add (if not using nmcli) IP addresses
/etc/network/interfaces.d/usb0.conf
allow-hotplug usb0
iface usb0 inet static
        address 192.168.30.1/24
If using Network Manager/nmcli there is a restriction that has to be lifted to make usb0 permanently managed, place
/usr/lib/udev/rules.d/85-nm-unmanaged.rules
into
/etc/udev/rules.d/
and replace the line
ENV{DEVTYPE}=="gadget", ENV{NM_UNMANAGED}="1"
with
ENV{DEVTYPE}=="gadget", ENV{NM_UNMANAGED}="0"
and then nmcli dev set usb0 managed yes
That's it
