Booot image form SD card
I tried to boot the debian from SD with the Method 2 (maskrom 3s) but the led SYS stayed red without any boot from the system.
Could you please give me more information how to boot from SD Card ?
I also tired ubuntu image with the same result... Do you have a idea about my issue ?
My sd is a SanDisk 128GB TF MicroSD U3 C10 A1 V30 4K.
Thanks in advance for your help.
Hi Jerome,
I would suggest that you try again using the current software. In my case I had success testing four of the images using the procedures documented in the wiki.
https://wiki.friendlyelec.com/wiki/index.php/NanoPi_R6S
I have the same problem, I don't have Windows I use "dd" command to write boot image into my sd card but it doens't work (black screen and red sys flag). I have also tryied this https://github.com/friendlyarm/sd-fuse_rk3588 but the result is the same.. is there someone that has flashed a boot image on sd card with Linux?
