Debian CM3588: Cannot install Home Assistant Supervised
As said, I'm tying to install Home Assistant Supervised on the CM3588. As Debian is the only supported distro for installing a supervised version, I'd try my luck.
Images used:
- rk3588-sd-debian-bookworm-core-6.1-arm64-20240522.img
- rk3588-sd-debian-bullseye-desktop-6.1-arm64-20240522.img
Every prerequisite runs fine, like installing dependencies, apparmor and Docker CE. Docker initializes fine and the service is running. However, after downloading and installing the HA .deb file, it fails when restarting the docker service.
During install the HA package adds a /etc/docker/daemon.json file (previously a blank file):
    "log-driver": "journald",
    "storage-driver": "overlay2",
    "ip6tables": true,
    "experimental": true,
    "log-opts": {
        "tag": "{{.Name}}"
After that, the installer tries to restart the docker service, resulting in an error. Running sudo dockerd --debug, I get (summary):
{[graphdriver] trying configured driver: overlay2
failed to mount overlay: invalid argument     storage-driver=overlay2
failed to start daemon: error initializing graphdriver: driver not supported: overlay2}
This happens on all instances I tried: Minimal, desktop, bookworm, bullseye etc. Could someone explain what could be wrong and how to correct it, if possible?
Note: Every other docker management system, Like OMV or CasaOS run fine (with a blank /etc/docker/daemon.json)
You can try changing the configuration to other storage drivers:
https://docs.docker.com/storage/storage ... ge-driver/
sudo passwd root  # Create a password for the root user if it hasn't been done before.
su - root -c 'echo "overlayfs=disable" > /.init_wipedata'
sudo reboot
from https://wiki.friendlyelec.com/wiki/inde ... _on_Debian
sudo reboot
see:https://wiki.friendlyelec.com/wiki/index.php/How_to_Install_Docker_on_Debian
@dragonfly
Same problem here with the new https://wiki.friendlyelec.com/wiki/index.php/NanoPi_M6 :(
I tried with Debian 12 core ... Debian 12 + Gnomes ... but the problem remains: Docker, docker compose, etc are working fine but Home Assistant Supervised not :(
Have you solved the problem with your CM3588?
In total there are 38 users online :: 0 registered, 0 hidden and 38 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 38 guests
