Developers attention please
So, I've got my CM3588 NAS kit and began to fiddle around with it. Starting with Android TV to compare it with another RK3588 box using Android TV. I found that there are some huge issues concerning refresh-rate availability and switching, making it somewhat useless as a all-round media player.
On the other RK3588, I can choose a HDMI resolution (like 4K@60), set the UI screensize to 1920x1080 @320DPI. Subsequently, I can then have have video apps like Smarttube or Kodi, switch between the available display modes (the system provides) and/or frame-rates depending on the video content used.
(click to open)
dumpsys display | grep mMode={id
      DisplayModeRecord{mMode={id=1, width=1920, height=1080, fps=60.0, alternativeRefreshRates=[24.0, 25.0, 30.0, 50.0]}}
      DisplayModeRecord{mMode={id=2, width=1920, height=1080, fps=50.0, alternativeRefreshRates=[24.0, 25.0, 30.0, 60.0]}}
      DisplayModeRecord{mMode={id=3, width=1920, height=1080, fps=30.0, alternativeRefreshRates=[24.0, 25.0, 50.0, 60.0]}}
      DisplayModeRecord{mMode={id=4, width=1920, height=1080, fps=25.0, alternativeRefreshRates=[24.0, 30.0, 50.0, 60.0]}}
      DisplayModeRecord{mMode={id=5, width=1920, height=1080, fps=24.0, alternativeRefreshRates=[25.0, 30.0, 50.0, 60.0]}}
      DisplayModeRecord{mMode={id=6, width=1280, height=720, fps=60.0, alternativeRefreshRates=[50.0]}}
      DisplayModeRecord{mMode={id=7, width=1280, height=720, fps=50.0, alternativeRefreshRates=[60.0]}}
      DisplayModeRecord{mMode={id=8, width=720, height=576, fps=50.0, alternativeRefreshRates=[]}}
      DisplayModeRecord{mMode={id=9, width=720, height=480, fps=60.0, alternativeRefreshRates=[]}}
(dumpsys taken from just a monitor, not a 4K TV, the list would then be far longer)
Anyway with this firmware, an attached TV can switch and match the original content's refresh rates. For example, playing a movie @23.976 FPS and thereby preventing artifacts like tearing, making it a perfect device for media playback.
However, with the latest FriendlyElec Android TV image, I can also choose HDMI resolutions, set the UI screensize, but apps are NOT provided with the supported modes, concerning all available res/refresh-rates.
      DisplayModeRecord{mMode={id=1, width=1920, height=1080, fps=60.000004, alternativeRefreshRates=[]}}
It has - probably - something to do with the h/w composer/displayservice not making the supported modes available to apps that support this. It would be GREATLY appreciated if this shortcoming could be corrected with an update or in the next release (along with the faulty HEVC 10bit HW video decoder)
Looks like the FriendlyElec build only exposes one display mode, which breaks refresh rate matching. Probably an HWC/EDID issue — hope multi-mode support is planned, it’s key for smooth media playback.
That’s a solid breakdown — the lack of proper refresh-rate switching really kills the media experience. Hopefully FriendlyElec addresses it in the next firmware.
Yes, that would be nice of them to do that update for Android / TV users... That would benefit everyone.
Add supportroid. for the Telit LM960A18 to Android
Telit LM960A18 isThe world's first global gigabit LTE module in the mPCIe (PCI Express Mini Card)
https://techship.com/product/telit-lm960a18-lte-cat-18-mpcie/?variant=003
