new t6 keeps booting into friendlyelec android
my new t6 doesn't want to boot from SSD into ubuntu. what procedure do i need to follow to get it to boot from the SD card ?
Zen
First question is "why don't you want to boot in Android?".
My reason was I wanted to replace the system with debian completely and start from nvme.
Experience learns one can roughly just erase the android image (can be restored if needed).
Using rkdeveloptool or (as linux user) upgrade_tool blank the emmc and rewrite the the spinor.
If you prefer a vanilla debian system try https://github.com/inindev/nanopc-t6/
Still requires you to blank the emmc and overwrite the spinor (I used the firnedlyelec sd-image for that purpose since it gives more control than using upgrade_tool).
With the friendlyelec image I suggest blanking the emmc and see if it works. If it doesn't work use the same spinor image as with armbian (the armbian installation manual uses a 2017.09 u-boot image, inindev uses a 2024.07 image). I expect the current armbian to have updated their u-boot. There are some minor nagging points with armbian making me prefer vanilla debian.
Use serial console or USB-to-serial adapter to access U-Boot and check the boot order. You can modify the boot priority to boot from the SD card or eMMC where your desired OS (like Linux) is installed.
Incredibox Sprunki
Power on your NanoPC-T6. It should automatically detect the SD card and boot from it. If it doesn't, you may need to adjust the boot order in the BIOS/UEFI settings to prioritize the SD card over other storage devices.
block blast
In total there are 258 users online :: 0 registered, 0 hidden and 258 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 258 guests
