Frustrated with my R6S: How do I get a custom image working?
I followed the instructions on the FriendlyElec Wiki trying to get either Fedora IoT or AlmaLinux installed on my NanoPi R6S, but I am not having much luck. Everything seems to install, that is the flasher goes through the process of installing the identified image, but after removing the SD card and rebooting, nothing happens after the FriendlyElec splash screen. Has anyone gotten a Fedora/RHEL adjacent distro working on a NanoPi? I very much prefer them and have them on all of my machines that are not MacOS; my RPi is running AlmaLinux 9.3 and everything else is Fedora 39 of some
I was able to install a custom image, with my own configuration on the EMMC. And it was booting.
Unfortunately, it bricked my board and i am now not able to access the EMMC anymore.
So make sure you get the image and its properties correct. Also try using the elfasher tool, which will install the custom OS from SD Card. if you have not tried it.
Hey there!
Yes, many people have been able to easily install Fedora or RHEL-based distributions on NanoPi boards. Check the NanoPi R6S's kernel version and configuration files (like /boot/config.txt) to make sure they are right. Make sure you've also chosen the right start mode, like U-start or UEFI.
you need to check the log via the serial port, make sure the bootloader is correct, replace or edit the correct DTB file for the hardware, and make sure the kernel supports the RK3588S SoC
Should work OOB from our build framework - simple and easy.
The board is RK3588S-based, and unlike the Raspberry Pi, which has extensive community support, slither Fedora and RHEL derivatives do not officially support RK3588(S) boards (yet).
Did you try connecting the NanoPi R6S to an HDMI monitor after boot to see if there’s any visual output or error messages?
Sometimes, using a different SD card or even reformatting it can make a difference. Have you tried connecting to the serial console during boot to see if there are any error messages?
In total there are 274 users online :: 0 registered, 0 hidden and 274 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 274 guests
