AP mode with multiple SSIDs on RTL8822CE
I've just started using R5C with the M.2 WiFi module RTL8822CE and overall things work well, however I'm unable to start the second WiFi network (like a GuestWiFi). One WiFi network works well, however once I add a second one in LuCI both SSIDs get marked as "disabled" and also none of the two can be seen by wireless devices. Once I disable one of the SSIDs the other one starts to work.
Is there a configuration option that I'm currently missing? Or is it that RTL8822CE does not support multiple SSIDs in the AP mode? I am running FriendlyWRT 23 with the preinstalled kernel 6.1.25
m-a-x-i-m-z wrote:
I've just started using R5C with the M.2 WiFi module RTL8822CE and overall things work well, however I'm unable to start the second WiFi network (like a GuestWiFi). One WiFi network works well, however once I add a second one in LuCI both SSIDs get marked as "disabled" and also none of the two can be seen by wireless devices google doodle baseball. Once I disable one of the SSIDs the other one starts to work.
In LuCI, go to `Network` -> `Wireless`. You should see your physical Wi-Fi device. Both your main SSID and your Guest SSID should be listed on this same physical wireless network. If they somehow try to use separate wireless interfaces, that could be a problem.
