R76S m.2 NVME
Hi!
I can't see my NVMe drive through the A/E-Key to M-Key adapter. Is this even possible?
use:
sk hynix nvme 256 gb 2230
OpenWrt 25 Snapshot kmod-nvme
avenger wrote:
Hi!
use:
If a PCIe connection is available, the SK Hynix 2230 NVMe drive should function normally.
Check that the A/E-Key slot on your router/board supports PCIe. The hardware documentation or schematic should make this clear.
Check that the adapter supports NVMe (PCIe) SSDs rather than only SATA-based M.2 drives.
