NanoPi R5S + RTC Clock
I am interested in purchasing a few NanoPi R5S. May I know if it comes with RTC Clock built-in?
It's got the clock but there's no battery hooked up to it so if you power off the device and restart the clock will go back to default. You can sync it with a NTP server though.
I think there is a connector for the clock battery. But I did not test.
That's because if the performance of the port is not good enough with a standard P2P test, it's not that useful to test the router function at this stage.
