Activate I2C-3- NanoPc-T4
HI everyone
I am working on the Nano PC - T4 with android 8 and Android 10 .
How can I activate the i2c3 form the source code?.
I implemented the following lines on the file
/path/Android/kernel/arch/arm64/boot/dts/rockchip/rk3399-nanopi4-common.dtsi
&i2c3 {
status = "okay";
but on the pins GPIO4_C1/I2C3_SCL(3V) and GPIO4_C0/I2C3_SDA(3V) of the 40 Pin GPIO connector I dont have voltage and no signals.
Thank's
Do you have the correct permissions set in the .rc file?
Hi v8dave
I Added for permissions after the ‘on boot’ section in the following files:
o Files:
• device/rockchip/common/recovery/etc/init.rc
• device/rockchip/rk3399/init.rk3399.rc
• system/core/rootdir/init.rc
o Lines:
#Coffee-Electronics
chown system system /dev/i2c-2
chmod 777 /dev/i2c-2
#Coffee-Electronics
chown system system /dev/i2c-3
chmod 777 /dev/i2c-3
Note:
but I dont have any signal on i2c3.
Thank's
When you open the device in code, do you get a filehandle or -1?
Hi v8dave
thank you for your support.
the i2c3 port is working now
I had a mistake on the android java code. with the number assigned to the i2c port.
with the previous post it is more than enough to activate the i2c3 port.
best regards
In total there are 14 users online :: 0 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 14 guests
