Ubuntu 18.04 Kernel header file
Posted: Fri May 15, 2020 3:14 am
I have to compile a driver for a device. It requires Kernel header file. Where can I find the installation package for Kernel header file. Thank you
http://ftp.friendlyarm.net/
Works with Armbian https://www.armbian.com/download/?tx_maker=friendlyelec
npropanol wrote:
You have to compile the headers from the source - basic instructions are here:
http://wiki.friendlyarm.com/wiki/index. ... n_OS_Image
I think I did
make ARCH=arm64 nanopi4-images headers_install deb-pkg
from a PC running ubuntu then installed the .deb on my NanoPi-M4.
A couple of things - I had to do a
make deb-pkg LOCALVERSION= KDEB_PKGVERSION=
otherwise it added a bunch of stuff to the filename so then the headers name didn't match.
Also, I think I had to add a patch from here:
https://forum.armbian.com/topic/9540-li ... -with-fix/
as the headers were coming out incomplete. The patch is about halfway down the page -
"fix-linux-headers-rk3399-pkg-v2.patch"
https://forum.armbian.com/applications/ ... hp?id=4021
Hope this helps.
Good Luck!
mikestanley464 wrote:
First check your installed kernel version as well as kernel header package that matches your kernel version using following commands.
$ uname -r
$ apt search linux-headers-$(uname -r)
Check Kernel Version and Kernel Headers in Ubuntu https://bluestacks.red https://omegle.red/
On Debian, Ubuntu and their derivatives, all kernel header files can be found under /usr/src directory. You can check if the matching kernel headers for your kernel version are already installed on your system using the following command.
$ ls -l /usr/src/linux-headers-$(uname -r)
Check Kernel Headers in Ubuntu
From the above output, it’s clear that the matching kernel header directory doesn’t exist, meaning the package is not yet installed.
Before you can install the appropriate kernel headers, update your packages index, in order to grab information about the latest package releases, using the following command.
$ sudo apt update
Then run the following command that follows to install the Linux Kernel headers package for your kernel version.
$ sudo apt install linux-headers-$(uname -r)
Install Kernel Headers in Ubuntu
Next, check if the matching kernel headers have been installed on your system using the following command
Verify Installed Kernel Headers in Ubuntu
That’s all! In this article, we have explained how to install kernel headers in Ubuntu and Debian Linux and other distributions in the Debian family tree.
Always keep in mind that to compile a kernel module, you will need the Linux kernel headers. If you have any quires, or thoughts to share, use the comment form below to reach us.
