Wireguard install...
I'm wanting to install Wireguard on the NanoPC-T3 and the difficulty is finding the build directory for for the installed kernel. It appears from
# uname -a
Linux matrix 4.4.49-s5p6818 #1 SMP PREEMPT Fri Mar 23 15:29:14 HKT 2018 aarch64 aarch64 aarch64 GNU/Linux
that I'm running the 4.4.49 kernel. There is a link in /lib/modules/4.4.49-s5p6818 that points build to /opt/FriendlyARM/nanopi3/linux-4.4.y but the link is dangling and there points at nothing. My question is where to download that build directory, or at least the part of the build directory needed to build the Wireguard kernel module.
The error from Wireguard is
$ make
make[1]: *** /lib/modules/4.4.49-s5p6818/build: No such file or directory. Stop.
Makefile:25: recipe for target 'module' failed
make: *** [module] Error 2
Note that I've successfully build Wireguard on x86 PCs running Artix linux and successfully on the Raspberry Pi 4 running Raspbian as well as Gentoo. The only difficulty with the T3 is that I'm missing the build directory that is needed to build out-of-tree kernel modules.
Before I try to rebuild the entire kernel over from scratch, is there someplace I can download the necessary directory for the vendor supplied kernel I already have installed?
Sorry, it seems I put this in the wrong forum. Could you please move to the T3?
- best 8812AU driver
- wireguard
- dkms
- kernel headers
= Armbian
- wireguard
- dkms
- kernel headers
= Armbian
Thanks for the quick reply. I've been running the 64-bit FriendlyCore distribution from FriendlyArm from the built-in eMMC flash. Is it possible and how do I install the Armbian Buster minimal distribution to eMMC? I see the download link here
https://www.armbian.com/nanopc-t3/
Ofc its possible.
https://docs.armbian.com/User-Guide_Get ... d-sata-usb
If you have eMMC model with 2G memory, you need to choose this board:
https://www.armbian.com/nanopc-t3-plus/
Or it wont't work.
Ofc its possible.
Or it wont't work.
Thanks! I've got Armbian installed on my NanoPC T3 now and WireGuard installed without any difficulties. Unfortunately, it would appear the Armbian kernel is not compiled with full iSCSI support, so I get something like
Mar 15 03:07:13 matrix iscsid[2207]: iSCSI logger with pid=2208 started!
Mar 15 03:07:13 matrix systemd[1]: iscsid.service: Failed to parse PID from file /run/iscsid.pid: Invalid argument
Mar 15 03:07:13 matrix iscsid[2208]: iSCSI daemon with pid=2209 started!
Mar 15 03:07:13 matrix iscsid[2208]: can not create NETLINK_ISCSI socket
Mar 15 03:08:43 matrix systemd[1]: iscsid.service: Start operation timed out. Terminating.
Mar 15 03:08:43 matrix systemd[1]: iscsid.service: Failed with result 'timeout'.
a 90 second delay when booting and, of course, no iSCSI either.
I'm not looking forward to building my own kernel. If I had wanted to do that, I would have stuck with the original FriendlyARM distribution. Any thoughts what to do next?
ejolson wrote:
Ofc its possible.
Or it wont't work.
Build system for creating your own Armbian kernel https://github.com/armbian/build is so simple that my mother could do that. You need a PC with Linux.
You can modify https://github.com/armbian/build/blob/m ... acy.config config (I would enable things but don't know exactly what you miss) and ask someone to build the kernel for you ... or wait for next release. Or download .deb build artefacts from Jenkins (if works) when making a PR.
Sticking to outdated FA distro is not what you want.
And this is possible only if you help https://www.armbian.com/donate/
I wonder if your mother has a computer science degree. Mine does, but even so, I'm pretty sure in her retirement she has not kept up with docker and other virtualized environments on Linux. Though not retired, neither have I. Will access to QEMU through a remote ssh session be sufficient?
While I understand the FriendlyARM distro is based off an earlier Ubuntu distribution, my only difficulty was lack of kernel headers for the default kernel. Obviously, building my own kernel would have solved that.
My understanding is that
CONFIG_INET=y
CONFIG_BLK_DEV_SD=y
CONFIG_SCSI_LOWLEVEL=y
CONFIG_ISCSI_TCP=M
CONFIG_SCSI_ISCSI_ATTRS=M
are needed for iSCSI support. See, for example,
https://wiki.gentoo.org/wiki/ISCSI/Initiator
Many of the Armbian kernels already have the iSCSI drivers built as modules and it is surprising the NanoPC T3 kernel does not. Note again that I somehow accidentally started this thread in the RK3399 forum rather than the S5P6818 section, so we are, in fact, talking about the 4.14.171-s5p6818 kernel here.
If you were able to change the above flags so the next automatic kernel build for the NanoPC T3 includes iSCSI support, I would greatly appreciate this. Unfortunately, I have never and don't know how to set up a forked GitHub repository and then issue a pull command for the needed changes.
CONFIG_INET=y
CONFIG_BLK_DEV_SD=y
CONFIG_ISCSI_TCP=M
It seems we have double postings. Please continue rather here
https://forum.armbian.com/topic/13347-n ... ment-97083
where I explained little more how things are. We have absolutely no resources to support you. Especially not in real time.
There are several thousands people already on the list with their small favour ... and we have a huge https://forum.armbian.com/forum/38-feature-requests/
