Dual MCAM400 support
I would like to work with two MCAM400 modules on a nanopi M4 in parallel. I read that this should be possible with the latest Image containing isp1. Is that right?
Can someone please provide a minimum working example for capturing both images to files.
Best regards
It's included in distro as a GStreamer bash script - dual-camera.sh
escobarrr wrote:
I didn't find it in distro, can you please help me ?
- you need a 201905xx friendlyelec distro (installed from scratch to be sure, and Desktop (you will not see second cam output in terminal\Core))
- type `which dual-camera.sh`
Still no working dual camera support even with the latest (20190625) version and I think I'm not the only one.
The csi1 connected camera is extremely slow and distorted.
Well, looks like it's working, but with stability issues.
Take a time to look at 'dmseg' output - it may look like this errors- showed for both old(isp10) and new(isp1) drivers. If you have similar errors - this is hardware stability issue (FriendlyElec develop & release both T4 & M4 without having working drivers to test Dual-camera mode).
It was some discussion in kernel thread about decreasing ISP frequency to increase stability, but it is no conformation about success.
