Can't get LVM to work.
I think I need to upgrade the kernel.
Got the NanoPi NEO-LTS 512M one with the UNO Dock V2.0 for NanoPi NEO and NanoHat OLED for NanoPi NEO/NEO2/NEO Plus2 and a NanoHat PCM5102A for audio.
I got two SSD's on it but 1TB and want them to look like a 2TB. I did this command:
root@NEO-doc2:~# lvdisplay
  /dev/mapper/control: open failed: No such device
  Failure to communicate with kernel device-mapper driver.
  Check that device-mapper is available in the kernel.
  Incompatible libdevmapper (unknown version) and kernel driver (unknown version).
  --- Logical volume ---
  LV Path                /dev/2-1TB-as-2TB/2TB-SSD
  LV Name                2TB-SSD
  VG Name                2-1TB-as-2TB
  LV UUID                xzqKJC-L4Ux-2bZu-CbMo-Fpi0-DVfA-i0N9uo
  LV Write Access        read/write
  LV Creation host, time NanoPi-NEO, 2021-06-01 06:35:10 -0400
  LV Status              NOT available
  LV Size                1.82 TiB
  Current LE             476917
  Segments               2
  Allocation             inherit
  Read ahead sectors     auto
root@NEO-doc2:~# mount /dev/2-1TB-as-2TB/2TB-SSD /media/2TB-SSD/                mount: special device /dev/2-1TB-as-2TB/2TB-SSD does not exist
root@NEO-doc2:~#
So do I need to upgrade the kernel to get it to work? If so how?
Thank you.
-Raymond Day
The link just show how to install the NanoHat OLED for NanoPi NEO/NEO2/NEO Plus2 and that is working good.
It sees the 2 drives as one big LVM but I can not mount it.
root@NEO-doc2:~#
I did a do-release-upgrade but it ends with this:
Not enough free disk space
The upgrade has aborted. The upgrade needs a total of 49.5 M free
space on disk '/boot'. Please free at least an additional 15.2 M of
disk space on '/boot'. You can remove old kernels using 'sudo apt
autoremove' and you could also set COMPRESS=xz in
/etc/initramfs-tools/initramfs.conf to reduce the size of your
initramfs
I put the SD card in Gparted on another PC and made the boot bigger and it still boots but looks like it did not see the bigger size. The /boot is in fat16.partiton.
-Raymond Day
Been trying to resize the /boot fat16 partition. It says it's 16.4kB but the system only see it as 7.2M. I used Gparted on anther system to resize it. But when I boot it don't use that size.
Here is some text from the command line.
root@NEO-doc2:~# parted /boot
Warning: Unable to open /boot read-write (Is a directory).  /boot has been
opened read-only.
opened read-only.
GNU Parted 3.2
Using /boot
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) p
Error: /boot: unrecognised disk label
Model:  (file)
Disk /boot: 16.4kB
Sector size (logical/physical): 512B/512B
Partition Table: unknown
Disk Flags:
(parted) quit
root@NEO-doc2:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            238M     0  238M   0% /dev
tmpfs            50M  5.0M   45M  11% /run
/dev/mmcblk0p2  104G  2.6G  101G   3% /
tmpfs           249M     0  249M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           249M     0  249M   0% /sys/fs/cgroup
/dev/mmcblk0p1   40M  7.2M   33M  18% /boot
tmpfs            50M     0   50M   0% /run/user/0
tmpfs            50M     0   50M   0% /run/user/1000
root@NEO-doc2:~#
Guess there is some file telling it was size it is and have to edit that but not sure.
I can't upgrade it because this /boot partition is to small.
-Raymond Day
Wow got it upgraded from:
Ubuntu Linux 16.04.7 to
Ubuntu Linux 18.04.5
I had to umount /dev/mmcblk0p1 the /boot partition.
Took about 4 hours or more and it rebooted fast and I did the mount of the LVM and I still get the same error!
It looks like this:
login as: root
root@neo-doc2's password:
 _____     _                _ _       _____ _     _____ ____
|  ___| __(_) ___ _ __   __| | |_   _| ____| |   | ____/ ___|
| |_ | '__| |/ _ \ '_ \ / _` | | | | |  _| | |   |  _|| |
|  _|| |  | |  __/ | | | (_| | | |_| | |___| |___| |__| |___
|_|  |_|  |_|\___|_| |_|\__,_|_|\__, |_____|_____|_____\____|
                                |___/
Welcome to Ubuntu 18.04.5 LTS 4.11.2
System load:   0.59             Up time:       8 min            Local users:   2
Memory usage:  26 % of 497Mb    IP:            192.168.86.36
CPU temp:      31°C
Usage of /:    3% of 104G
 * Documentation: http://wiki.friendlyarm.com/Ubuntu
 * Forum: http://www.friendlyarm.com/Forum/
Last login: Tue Jun  8 18:09:44 2021 from 192.168.86.95
mount: /media/2TB-SSD: special device /dev/2-1TB-as-2TB/2TB-SSD does not exist.
root@NEO-doc2:~#
Don't get why the command still don't mount the LVM just says does not exist. Best guess is I have to edit some boot file that it could not touch because I unmounted it and that was the only way to upgrade it.
-Raymond Day
This is the only hw specific function that might not work, but it works. Everything else is classes better, LVM must work. If not, rebuilding is easy.
