R4S images do not boot
I'm trying to get either Debian Core or FriendlyCore (I'm presuming that is some kind of Ubuntu derivative) to run on my R4S. It is running OpenWRT from the OpenWRT site (]rk3399-sd-friendlywrt-22.03-20230210.img.gz) and it runs OK. So the R4S is not to blame.
Both the Debian Core image and the FriendlyCore image have an unusual partition layout:
GPT fdisk (gdisk) version 1.0.9
Partition table scan:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/sde: 124735488 sectors, 59.5 GiB
Model: USB3.0 CRW   -SD
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): 73987B6B-4974-4C94-A3E8-58AB2EB7A946
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 15234340
Partitions will be aligned on 2048-sector boundaries
Total free space is 16350 sectors (8.0 MiB)
Number  Start (sector)    End (sector)  Size       Code  Name
   1           16384           24575   4.0 MiB     FFFF  uboot
   2           24576           32767   4.0 MiB     FFFF  trust
   3           32768           40959   4.0 MiB     FFFF  misc
   4           40960           49151   4.0 MiB     FFFF  dtbo
   5           49152           81919   16.0 MiB    FFFF  resource
   6           81920          163839   40.0 MiB    FFFF  kernel
   7          163840          262143   48.0 MiB    FFFF  boot
   8          262144         2752511   1.2 GiB     FFFF  rootfs
   9         2752512        15234340   6.0 GiB     FFFF  userdata
This is from rk3399-sd-debian-bullseye-core-4.19-arm64-20230314.img. I uncompressed the img.gz file to avoid any error from a gzip | dd pipe because of alignment or something like that, though I've never encountered such a problem before.
Note that the partition codes are all zero, which is very unusual for a GPT partition. I ran the "strings" program on the first partition, and it turned up a lot of strings that looked like they came from various programs, so that might indeed be a uboot partition.
The R4S I bought is with enclosure, so I don't want to open that to not loose the warranty. I can't access the serial console to debug this problem.
I presume that images on Google Drive at …/NanoPi_R4S_series/01_Official images/01_SD card images should be usable with a regular R4S, but I have no idea how to get them to run.
Did you try https://www.armbian.com/nanopi-r4s/ ?
