M4 : update kernel and dtb files
Posted: Mon Mar 16, 2020 11:43 pm
by GoblE
I'm user of this very good board which is NanoPi M4.
I would like to add CAN-BUS support to the friendlyCore image by updating kernel, dtb and modules files of my current SDcard.
Problem that I have : I don't understand how I can replace current files of my SDcard, without reflasing all the SDcard (eflasher) ? I saw "linux upgrade tool" too, but I can't see information about dtb file.
I checked uboot, but I only saw address without clear location. I suspect files are stored into the raw partition of the SDcard.
If you have solution to replace kernel and dtb file I'm interested.
Thank you.
Re: M4 : update kernel and dtb files
Posted: Fri Mar 20, 2020 11:17 pm
by GoblE
Nobody know where are stored and how we can do to update kernel and dtb files of the rk3399-sd-friendlycore-bionic-4.4-arm64 image ?
Posted: Sat Mar 21, 2020 9:12 am
by igorp
With Armbian playing with this its easier.
https://forum.armbian.com/topic/13347-n ... ment-97310
https://forum.armbian.com/topic/13389-s ... ment-97352
Posted: Sat Mar 21, 2020 10:25 am
by GoblE
Thank you for your help igorp!
Nice mechanism, unfortunately is not the same with friendlycore image :cry:
Kernel and dtb files seem to be stored in the sdcard, but where....
Posted: Sat Mar 21, 2020 11:31 am
by igorp
Armbian support is much better and there are more people which can help you.
https://docs.armbian.com/#what-is-armbian
I only tried this once, probably on separate partition.
Posted: Sun Mar 22, 2020 10:05 pm
by GoblE
Ok, I did lot of things on my current image so I'll try to find a solution but it's good thing to know for the future, before to start an embedded development. thanks for your feedback igorp.
Yes, I think too. I suspect that the first "unused" memory area contains raw data :
Posted: Sun Mar 22, 2020 10:11 pm
by igorp
Currently you are not receiving any updates. Not functional nor security for the most important part. That doesn't bothers you?
Posted: Mon Mar 23, 2020 12:06 am
by GoblE
For my current use case no, it's a POC, not connected to the web. If this kernel information was not missing, my POC would be finished :|
Posted: Wed Mar 25, 2020 10:55 pm
by GoblE
Ok I found the solution! Based on provided scripts from FriendlyARM (sd-fuse_rk3399), I made this script to flash parameters, kernel and dtb files only into the first raw partition.
I copied usefull files next to my script :
- kernel.img (kernel binary)
- resource.img (dtb, logo, etc)
- param4sd.txt (from sd-fuse_rk3399 repo)
- parameter.txt (from sd-fuse_rk3399 repo)
- partmap.txt (from sd-fuse_rk3399 repo)
- sd_update (from sd-fuse_rk3399 repo)
#!/bin/bash
# flash=mmc,1:kern:raw:0x2000000,0x2000000:kernel.img;
# flash=mmc,1:boot:raw:0x4000000,0x2000000:boot.img;
# Checking device for fusing
if [ $# -eq 0 ]; then
   echo "Usage: $0 DEVICE"
   exit 0
fi
case $1 in
/dev/sd[a-z] | /dev/loop[0-9]* | /dev/mmcblk[0-9]*)
   if [ ! -e $1 ]; then
      echo "Error: $1 does not exist."
      exit 1
   fi
   DEV_NAME=`basename $1`
   BLOCK_CNT=`cat /sys/block/${DEV_NAME}/size` ;;&
/dev/sd[a-z])
   DEV_PART=${DEV_NAME}1
   REMOVABLE=`cat /sys/block/${DEV_NAME}/removable` ;;
/dev/mmcblk[0-9]* | /dev/loop[0-9]*)
   DEV_PART=${DEV_NAME}p1
   REMOVABLE=1 ;;
   echo "Error: Unsupported SD reader"
   exit 0
esac
if [ ${REMOVABLE} -le 0 ]; then
   echo "Error: $1 is a non-removable device. Stop."
   exit 1
fi
if [ -z ${BLOCK_CNT} -o ${BLOCK_CNT} -le 0 ]; then
   echo "Error: $1 is inaccessible. Stop fusing now!"
   exit 1
fi
let DEV_SIZE=${BLOCK_CNT}/2
if [ ${DEV_SIZE} -gt 64000000 ]; then
   echo "Error: $1 size (${DEV_SIZE} KB) is too large"
   exit 1
fi
true ${MIN_SIZE:=600000}
if [ ${DEV_SIZE} -le ${MIN_SIZE} ]; then
    echo "Error: $1 size (${DEV_SIZE} KB) is too small"
    echo "       please try another SD card."
    exit 1
fi
cp ../kernel-rockchip/*.img $(dirname $0)
RKPARAM=$(dirname $0)/parameter.txt
RKPARAM2=$(dirname $0)/param4sd.txt
# Automatically re-run script under sudo if not root
if [ $(id -u) -ne 0 ]; then
   echo "Need sudo..."
   sudo "$0" "$@"
fi
# Get host machine
ARCH=
if uname -mpi | grep aarch64 >/dev/null; then
   ARCH=aarch64/
fi
# umount all at first
umount /dev/${DEV_NAME}* > /dev/null 2>&1
sync
# partition card & fusing filesystem
true ${SD_UPDATE:=$(dirname $0)/sd_update}
[[ ! -f "${RKPARAM}" ]] && exit 0
PARTMAP=$(dirname $0)/partmap.txt
PARAM4SD=$(dirname $0)/param4sd.txt
# Prepare image for sd raw img
#     emmc boot: need parameter.txt, do not need partmap.txt
#     sdraw: all need parameter.txt and partmap.txt
if [ ! -f "${PARTMAP}" ]; then
      echo "File not found: ${PARTMAP}, please download the latest version of the image files from http://dl.friendlyarm.com/nanopct4"
      exit 1
fi
if [ ! -f "${PARAM4SD}" ]; then
      echo "File not found: ${PARAM4SD}, please download the latest version of the image files from http://dl.friendlyarm.com/nanopct4"
      exit 1
fi
# write ext4 image
${SD_UPDATE} -d /dev/${DEV_NAME} -p ${PARTMAP}
if [ $? -ne 0 ]; then
   echo "Error: filesystem fusing failed, Stop."
   exit 1
fi
if [ -z ${ARCH} ]; then
   partprobe /dev/${DEV_NAME} -s 2>/dev/null
fi
   echo "Warning: Re-reading the partition table failed"
else
  sleep 1
  resize2fs -f /dev/${DEV_PART}
fi
sync
echo "---------------------------------"
echo "All done."
