Antennas and cooling fan NanoPC-T4
Can somebody tell me how i get those two antennas to run on Armbian?
Would be cool to use them......
https://imgur.com/a/i3czvHg
And by the way, which are supported cpu cooling fans.....i mean,what are the dimensions i need for the t4?
how do i check? never bought a cooling fan before :P
Thanks and best regards
Antennas are part of Wifi and bluetooth. You need to remove them from case and have them vertical and separate. Like you see on wifi routers.
Fan for heatsink should be 40 or 50 mm, same size as heat sink. make sure it is same voltage as the fan header gives.
Heat sink needs air flow so dont block it leave your case internals fee of cables etc.
