SOM-RK3399 & SOM-RK3399V2 Pin-to-pin compatible?
We would like to switch from SOM-RK3399 to SOM-RK3399V2. Are those pin-to-pin compatible?
Also is dev board for SOM-RK3399 suitable for SOM-RK3399V2?
Kirill
The documentation for both can be studied to determine if the pins are the same. I suspect they are and the difference is in the board layout. In fact, looking at the wiki and doing a side by side comparison, the connections are identical.
Thanks! It also looks to me that they are compatible but decided to double check.
