Safe temp?
Hi
Were wondering what is a safe temperature to run the NanoM4 @ for long periods of time?
With the large heatsink, running CPU at 100% for many hours, it creeps up to 70 degrees without a fan.
This seems high to us to run for long periods of time
Whats the design temp?
David
loopdavid wrote:
Hi
David
I'm not speaking for the NanoPi M4 specifically, but 70 degrees is generally a safe temperature for a single board computer. For example, the raspberry pi starts underclocking itself at 85 degrees, and gets damaged at 90 degrees.
When it comes to the NanoPi M4, I have run it for more than a week on 100% cpu (about 65-70 degrees) without any side effects. If you plan on overclocking, or keeping it in a warm environment, you could consider a fan.
In total there are 30 users online :: 0 registered, 0 hidden and 30 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 30 guests
