FriendlyWRT missing "kmod-ipt-nat6" package
I'm trying to migrate my router to my NanoPI R4S and one of my required packages for my LAN is not available in the repository for this chip.
The package is: https://openwrt.org/packages/pkgdata/kmod-ipt-nat6
Error is
 FriendlyWrt 19.07.5, r11257-5090152ae3
root@FriendlyWrt:~# opkg update
Downloading http://downloads.openwrt.org/releases/19.07.5/packages/aarch64_cortex-a53/base/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_base
Downloading http://downloads.openwrt.org/releases/19.07.5/packages/aarch64_cortex-a53/base/Packages.sig
Signature check passed.
Downloading http://downloads.openwrt.org/releases/19.07.5/packages/aarch64_cortex-a53/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_luci
Downloading http://downloads.openwrt.org/releases/19.07.5/packages/aarch64_cortex-a53/luci/Packages.sig
Downloading http://downloads.openwrt.org/releases/19.07.5/packages/aarch64_cortex-a53/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_packages
Downloading http://downloads.openwrt.org/releases/19.07.5/packages/aarch64_cortex-a53/packages/Packages.sig
Downloading http://downloads.openwrt.org/releases/19.07.5/packages/aarch64_cortex-a53/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_routing
Downloading http://downloads.openwrt.org/releases/19.07.5/packages/aarch64_cortex-a53/routing/Packages.sig
root@FriendlyWrt:~# opkg install kmod-ipt-nat6
Unknown package 'kmod-ipt-nat6'.
Collected errors:
 * opkg_install_cmd: Cannot install package kmod-ipt-nat6.
I expected this to work since its a core package?
For non NanoPI devices it works...
 OpenWrt 19.07.7, r11306-c4a6851c72
root@OpenWrt:~# opkg update
Downloading http://downloads.openwrt.org/releases/19.07.7/targets/x86/64/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_core
Downloading http://downloads.openwrt.org/releases/19.07.7/targets/x86/64/packages/Packages.sig
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/base/Packages.gz
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/base/Packages.sig
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/freifunk/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_freifunk
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/freifunk/Packages.sig
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/luci/Packages.gz
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/luci/Packages.sig
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/packages/Packages.gz
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/packages/Packages.sig
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/routing/Packages.gz
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/routing/Packages.sig
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/openwrt_telephony
Downloading http://downloads.openwrt.org/releases/19.07.7/packages/x86_64/telephony/Packages.sig
root@OpenWrt:~# opkg install kmod-ipt-nat6
Installing kmod-ipt-nat6 (4.14.221-1) to root...
Downloading http://downloads.openwrt.org/releases/19.07.7/targets/x86/64/packages/kmod-ipt-nat6_4.14.221-1_x86_64.ipk
Installing kmod-nf-nat6 (4.14.221-1) to root...
Downloading http://downloads.openwrt.org/releases/19.07.7/targets/x86/64/packages/kmod-nf-nat6_4.14.221-1_x86_64.ipk
Configuring kmod-nf-nat6.
Configuring kmod-ipt-nat6.
An OpenWRT developer said that FriendlyWRT is missing kernel definitions / targets and that FriendlyWRT must fix them. source: https://forum.openwrt.org/t/opkg-reposi ... 3/100091/3
Would this post in this forum get the right visibility to get that fixed? It prevents me from using FriendlyWRT on my LAN due to requiring IPv6 NAT6.
