MiniPCIe on NanoPi Duo
I am trying to build a wifi mesh network for urban robotics and would like to use the nanopi duo for the meshnetworking algorithms. I saw that an option for purchasing the NanoPi Duo is the "Kingspec 64GB MiniPCIe mSATA Half-size SSD for Industrial (+$45.00)", while I don't want to purchase this SSD I would like to purchase this WiFi Transciever on Mouser
https://www.mouser.com/ProductDetail/Do ... LDdA%3d%3d
That uses a MiniPCIe. Does anyone have any experience doing anything similar? Is there any documentation you can point me towards?
Thanks in advance!
But there will be firstly another problem: the WiFi-Card is MiniPCIe full lenght and the Mini-Shield-Board for the Duo
has one a free place for a half-szie MiniPICe-Card
See the Duo-Set at:
https://www.friendlyarm.com/index.php?r ... uct_id=198
Or do you want to build your own shield-pcb?
Thanks in advance!
That is mSATA implementation only. Not mPCI
@guidol - Thanks for the response. I am planning on doing a custom PCB, I am mainly concerned with the schematic to get the Duo to communicate over MiniPCIe and not the physical size (unless there is a non-physical fit issue I am missing).
Thanks again,
Andy
Thanks again,
Andy
I am trying to build a wifi mesh network for Vidmate iTunes Notepad++ urban robotics and would like to use the nanopi duo for the meshnetworking algorithms. I saw that an option for purchasing the NanoPi Duo is the "Kingspec 64GB MiniPCIe mSATA Half-size SSD for Industrial (+$45.00)", while I don't want to purchase this SSD I would like to purchase this WiFi Transciever on Mouser
But it will not work.
the user JAGITA does only copy questions from other users (like here from the Thread-opener "oneCuil")
JAGITA did this in 20 posts and did not wrote a own sentence - I did report him to FriendlyElec.
