NEO2 Ubuntu Static IP not working
Running a NEO2 with a NAS DOC on Ubuntu Xenial.
I have tried several ways to configure Static IP address and it looses all connectivity to eth0 and need to enter system via the serial port.
Is there a different approach to:
sudo nano /etc/network/interfaces
auto eth0
iface eth0 inet static
address 192.168.1.120
netmask 255.255.255.0
gateway 192.168.1.1
All I can suggest is looking at the RaspberryPi forums. There is discussion about setting up static IPs which I think involved changing dhcpd,conf
Good luck!
I tried this once and failed, so I searched some more without any luck. Went back to ModMyPi.
So I tried again by editing the dhcpcd.conf file, that did not exist in /etc
sudo nano /etc/dhcpcd.conf
And added:
nohook lookup-hostname
interface eth0
static ip_address=192.168.1.121/24
static routers=192.168.0.1
static domain_name_servers=192.168.0.1
press ctrl+x to exit, “Y” to save, reboot and ifconfig and it worked!!!
