Nanopi Neo - LVM and luks crypted volume issue.
I'm trying to mount luks crypted volume, but i've got only:
Cannot initialize device-mapper. Is dm_mod kernel module loaded?
I can't find dm_mod module or add in some way to the system.
I'm using Xenial 4.x, but same situation is in Debian Jessie.
Crypted volumes works fine on Armbian, but system is unstable, after a hour i've getting "Out of memory" and can't access it using ssh or even debug port.
Kernel 4.y is in a testing stage, so problems are possible. In case you encounter them, roll kernel a version or two back and wait for a proper fix.
https://forum.armbian.com/topic/6386-li ... ment=48809
