Only see 512RM RAM with OS with 1 GB Board.
Hey all,
I am only seeing 512MB Ram and I have a 1 GB board, anything I can do so it sees the rest of the ram? Tried to figure it out but no clue.
maurddz wrote:
Hey all,
You must be using wrong bootloader/image. Try correct image https://www.armbian.com/download/
If you could tell us which board do you have with 1GB then we could give you the right link to a image.
And which image did you use to boot?
Hi,pls loading an SD card with the newest Ubuntu build with kernel 4.14https://drive.google.com/drive/folders/1w7eMluHWo3ezwKBdaJcDUcCtM9qVaaVv?usp=sharing
Hello and thanks for the response. I just used the image that came preinstalled on the sdcard as I ordered a Neo2 with the OLED and case as I am new to nano sized computers but not new to Linux. I didn't realize I would need a new image just because I have more ram. When I get to my machine, i will post more info. For now, I will read about loading a new image.
as I am new to nano sized computers but not new to Linux. !
When you ordered a NanoPi Neo2 with OLED-Hat and (the black) case like:
http://www.friendlyarm.com/index.php?ro ... uct_id=190
then you only got 512MB of DDR3 Ram and you will never see more.
NanoPi Neo 2: http://www.friendlyarm.com/index.php?ro ... uct_id=180
Maybe you do think it has 1GB, because the new NanoPi Neo Core2 has 1GB of DDR3 Ram:
http://www.friendlyarm.com/index.php?ro ... uct_id=211
For the 512MB NanoPi Neo2 the actual OLED Image nanopi-neo2_ubuntu-oled_4.14.0_20171219.img.zip
is at:
https://drive.google.com/open?id=1gGoGd ... RYXhzECsLG
Yes I made sure to order the 1GB one.
NEO2 Complete Starter Kit
- DDR3 RAM: 1 GB RAM
is in my email and here is the link http://www.friendlyarm.com/index.php?ro ... uct_id=189 Has an $8 1 GB upgrade option.
piipi@NEOS:~$ uname -a
Linux NEO2 4.11.0-rc4 #37 SMP Thu May 4 01:43:10 CST 2017 aarch64 aarch64 aarch64 GNU/Linux
~$ free
total used free shared buff/cache available
Mem: 494760 107808 187744 1716 199208 363480
Swap: 0 0 0
~$ cat /etc/issue
Ubuntu 16.04.2 LTS \n \l
So is it the wrong image? With I use apt-get ... it's using ubuntu-ports xenial as the source.
I just want to make sure before I upgrade as I did alot of customizations already :)
Ohh - I didnt know about this 1GB option for the Neo2 (Kit) - because on the normal Neo2 (without case) there isnt a 1GB option
(only a not useable option for 512MB - because it aleready has 512MB).
In my Opinion they made a mistake at the Neo2 Kit Page and the 1GB "option" is for the 512MB.....
But ask FriendlyARM-Support directly (would be a nice option to get a 1GB Neo2).....but I havent seen before a Neo2 with 1GB of Ram :(
You are using some beta image with a beta kernel which will never get an update with an apt update.
To be sure that you have a real 1Gb board you need to provide:
- hires pictures of PCB, both sides
If you indeed have 1Gb board, try this option
- download latest Armbian for NEO2, nightly and update to the most recent kernel (4.14.13) with apt update
- attach serial console and provide its log
I already briefly checked and it seems that there are no special settings and 1Gb version must just work. At least kernel wise.
My NanoPi Neo Core2 - with 1GB Ram - is also using the normal NanoPi Neo2 armbian image and is showing the full 1GB of Ram without any special settings:
Welcome to ARMBIAN 5.37.180112 nightly Debian GNU/Linux 9 (stretch) 4.14.13-sunxi64
Memory usage:  14 % of 994MB
KiB Mem :  1018032 total,   442988 free,   150028 used,   425016 buff/cache
KiB Swap:   131068 total,   131068 free,        0 used.   773292 avail Mem
Hey all and thanks again for the responses. I do remember there being a sticker on the NIC that said 1GB but I will take it apart tonight and take some photos.
I also do not know of a setting to enable or activate that enables 1Gb of ram vs 512. In my experience, if you have more than 64GB then a kernel option needs to be included in the recompile of the kernel.
I will try a armbian image tonight and see if that fixes it. I did not realize I was running a beta kernel. I mostly use Slackware so debian is kinda of new to me as it's a little different.
Thanks again all.
All is good now. I installed Armbian and now I see the full 1024 MB of ram. My OLED screen doesn't work anymore so I am figuring that out, any suggestions?
Sorry I cant help here... I also got a normal Neo (not Neo2) with OLED-Hat, but the display will only run with a (in my opinion) kernel-module/software which isnt available in armbian.
The OLED-Hat-Wiki at
http://wiki.friendlyarm.com/wiki/index.php/NanoHat_OLED
tell us to use a customized ROM-image with xxx-OLED-xxx (Section Install Software)
There must be something "special" inside .
The /etc/rc.local is starting /usr/local/bin/oled-start
which then is starting /root/NanoHatOLED/NanoHatOLED
Maybe it will be only a copy of the directory /root/NanoHatOLED/ and /usr/local/bin/oled-start
and starting /usr/local/bin/oled-start in the /etc/rc.local of armbian?
[EDIT]
I did try it - but it didnt work :(
I gziped NanoHatOLED and copied and extracted it,
I copied
- /usr/local/bin/oled-start
- /usr/local/bin/gpio
- /root/NanoHatOLED/NanoHatOLED
I installed WiringNpi in /root via the instructions at https://github.com/friendlyarm/WiringNP
And checked in the OLED-Image which hardware has to be enabled:
I2C0, I2C1, I2C2, SPI0
But after a reboot the /System/Hardwaretoogle in armbian-config couldnt start up because of
ls: sed: -e expression #1, char 8: unterminated `s' command
sed: -e expression #1, char 13: unterminated `s' command
cannot access '/boot/dtb/overlay/Binary': No such file or directory
ls: cannot access 'file': No such file or directory
ls: cannot access '(standard': No such file or directory
ls: cannot access 'input)': No such file or directory
ls: cannot access 'matches*.dtbo': No such file or directory
Maybe the WiringNP-Installation did broke armbian :(
