Configuring GPIO pin mapping for libgpiod
Hi
I installed a bare minimal Debian 11 (Bullseye) distribution on a Nano Pi M1 single board computer. I would like to use it to control external devices using its GPIO pins. I was not able to find a suitable port of Python packages such RPi.GPIO for this purpose. Besides I understand the current best practice for controlling gpio pins is to use libgpiod. The gpio device is detected by the kernel as shown below
$ sudo gpiodetect
gpiochip0 [1c20800.pinctrl] (224 lines)
gpiochip1 [1f02c00.pinctrl] (32 lines)
However the pins are not named and so it is not obvious how the libgpiod pin numbers map to pins on the Nano Pi M1 board as shown below
$ sudo gpioinfo gpiochip0
gpiochip0 - 224 lines:
   line   0:      unnamed       unused   input  active-high
   line   1:      unnamed       unused   input  active-high
   line   2:      unnamed       unused   input  active-high
   line   3:      unnamed       unused   input  active-high
   line   4:      unnamed       unused   input  active-high
   line   5:      unnamed       unused   input  active-high
   line   6:      unnamed       unused   input  active-high
   line   7:      unnamed       unused   input  active-high
   line   8:      unnamed       unused   input  active-high
   line   9:      unnamed       unused   input  active-high
   line  10:      unnamed "nanopi:blue:status" output active-high [used]
How do I find out what libgpiod pin numbers map to what pins on the Nano Pi M1 board ?
Is there any way to set names for these pins ?
I'm encountering the same problem - don't know how to map lines to actual GPIO pins on the Nano Pi. Does anyone have any info on this?
