NanoPi Duo2 what pins can you use to power
Posted: Fri Oct 04, 2019 2:54 pm
by bobt
I don't want to use the USB jack to power the NanoPi so can I use the 5V In/Out and Ground pin to power the unit?
Just making sure thats OK. I searched for backpowering the unit but could not find any information on that.
Also is there going to be a version of the adapter card with a 4G or 3G cell modem?
Bob
Re: NanoPi Duo2 what pins can you use to power
Posted: Sun Oct 06, 2019 8:23 am
by guidol
check the page
http://wiki.friendlyarm.com/wiki/index.php/NanoPi_Duo2
there you could see on the upper left 2 Pins for +5V IN/OUT (5V VDD) and then after the 3.3V (OUT-Pin - do connect nothing to this) is GND = Minus/earth
