NanoPi-R1 Install image on eMMC
Hi!
I am trying to install nanopi-r1_eflasher_friendlywrt_4.14_armhf_20190826.img on the internal eMMC chip. I followed the procedure as described in the Wiki, but I only see the red LED blinking and no net activity at all (to ssh into the box and proceed). When I boot from an SD card, everything is fine and works as expected.
Is there some special trick involved? I've done a similar installaion on a NanoPC-T4, but in this case I started the installation from the local monitor/keyboad/mouse, which the R1 doesn't have.
It turned out that I used a bogus IP on the LAN side all the time...
Everything is fine now.
In total there are 58 users online :: 0 registered, 0 hidden and 58 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 58 guests
