Armbian for Neo2 - first stable test build with 4.13.5
After months of hard work, Armbian has come out with first stable test image (CLI or desktop) with a modern kernel 4.13.5. Welcome to check out what and how it works. Beware that (minor) troubles are still expected - but now we would like to hunt them. If you don't want to receive daily updates and risk freezing, freeze kernel updating in armbian-config. Detailed info about what was done and what are still limitations is under construction. Test images for other similar boards will follow when becoming ready.
https://www.armbian.com/nanopi-neo-2
Thank you for your donation.
This means the nanopi-neo2_debian-core-jessie_4.11.0_20170428.img is now completly dead (image isnt available anymore with direct link)?
Is the 4.13.5 Kernel mainline stable as this old testing?
Thanks now for trouble-hunting :) My Neo2 was quite useful with the old version - now I will try the new one :)
Done:
 _   _                   ____  _   _   _              ____
| \ | | __ _ _ __   ___ |  _ \(_) | \ | | ___  ___   |___ \
|  \| |/ _` | '_ \ / _ \| |_) | | |  \| |/ _ \/ _ \    __) |
| |\  | (_| | | | | (_) |  __/| | | |\  |  __/ (_) |  / __/
|_| \_|\__,_|_| |_|\___/|_|   |_| |_| \_|\___|\___/  |_____|
Welcome to ARMBIAN 5.33.171011 nightly Ubuntu 16.04.3 LTS 4.13.5-sunxi64
System load:   0.09 0.48 0.30   Up time:       6 min
Memory usage:  6 % of 482MB     IP:            192.168.6.22
CPU temp:      40°C
Usage of /:    9% of 15G
[ 0 security updates available, 1 updates total: apt upgrade ]
Last check: 2017-10-10 23:46
Last login: Tue Oct 10 23:46:30 2017 from 192.168.6.17
root@nanoneo2:~# uname -a
Linux nanoneo2 4.13.5-sunxi64 #23 SMP Tue Oct 10 02:43:15 CEST 2017 aarch64 aarch64 aarch64 GNU/Linux
Yes, this should be stable but what is more important - it comes with long-term support. Updates to firmware come standard Debian way.
I am not sure everything is working perfectly since this is usually seen when you work with it for weeks. We didn't put this image through our regular testing process yet. That's why it's named "test build" and it's probably the best what's possible at the moment.
If someone wants to help make this Linux better, join ours testings. Sent @Tido a message. https://forum.armbian.com/index.php?/to ... re-freeze/
Great news!
Is NEON and AES encryption/decryption enabled on this build?
q-bert wrote:
Great news!
It should be. If you need anything special and we forget to add:
https://github.com/armbian/build/blob/m ... ext.config
Welcome to push changes.
I downloaded "Armbian_5.34.171031_Nanopineoplus2_Ubuntu_xenial_next_4.13.10.7z" and flashed it on a Sandisk micro sd card with Etcher. Unfortunately neo2plus does not boot. After removing the micro-sd card the board boots normally (Friendlyarm's Ubuntu on emmc).
Should I try a different image?
Nanopi Neo Plus2 is different board and it works partially with normal Neo2 image.
https://dl.armbian.com/nanopineo2/Ubunt ... nightly.7z
Boot logs with:
Nanopi Neo2
http://sprunge.us/XMZG
Nanopi Neo plus2
http://sprunge.us/PRUT
... while https://dl.armbian.com/nanopineoplus2/U ... nightly.7z with Nanopi Neo plus2 breaks here:
U-Boot 2017.09-armbian (Oct 30 2017 - 03:03:57 +0100) Allwinner Technology
CPU:   Allwinner H5 (SUN50I)
Model: FriendlyARM NanoPi NEO Plus 2
DRAM:  512 MiB
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
230454 bytes read in 137 ms (1.6 MiB/s)
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot/boot.scr
3100 bytes read in 185 ms (15.6 KiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
116 bytes read in 155 ms (0 Bytes/s)
** File not found /boot/dtb/allwinner/sun50i-h5-nanopi-neo-plus2.dtb **
Kernel DT bits are non existing for Neo Plus2 ... since its still Work in progress. https://www.armbian.com/work-in-progress/
+2 model will be added when possible.
Got it, thanks for the explanation.
In total there are 40 users online :: 0 registered, 0 hidden and 40 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 40 guests
