EFlasher Image Single File For NEO PLUS2
I am trying to find a single file img rom for eflasher For NEO PLUS2 , but i cannot find (or a tutorial how to combine the 8 files into one to burn into sd)
Is there a link to this file ?
I get the below on console , can somebody help me resolve ?
U-Boot SPL 2017.11-05001-gffaf107328 (Dec 23 2019 - 16:53:05)
DRAM: 512 MiB(504MHz)
CPU Freq: 408MHz
memory test: 1
Pattern 55aa  Writing...Reading...OK
Trying to boot from MMC1
Boot device: sd
NOTICE:  BL3-1: Running on H5 (1718) in SRAM A2 (@0x44000)
NOTICE:  Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):0fc0ec6
NOTICE:  BL3-1: Built : 14:33:21, Dec  8 2017
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9
U-Boot 2017.11-05001-gffaf107328 (Dec 23 2019 - 16:53:05 +0800) Allwinner Technology
CPU:   Allwinner H5 (SUN50I)
Model: FriendlyElec NanoPi H5
DRAM:  512 MiB
CPU Freq: 1008MHz
    serial
Out:   serial
Err:   serial
:   No ethernet found.
BOARD: nanopi-neo-plus2
starting USB...
No controllers found
.?.?+??.boot.scr????W?gJ??19 ms (48.8 KiB/s).?00000
CPU Freq: 408MHz
memory test: 1
From where i can download EFlasher for neo PLUS2 ? i can't find the img file can you help ?
Can't find this suggested file XXXX-eflasher-YYYYMMDD-full.img.7z
Can someone help on this ?
Boot device: sd
NOTICE:  BL3-1: v1.0(debug):3ae819c
NOTICE:  BL3-1: Built : 19:09:36, Dec 19 2019
NOTICE:  DT: sun50i-h5-nanopi-neo2
NOTICE:  SCPI: dummy stub handler, implementation level: 000000
U-Boot 2017.11 (Dec 19 2019 - 19:09:39 +0800) Allwinner Technology
DRAM:  512 MiB
CPU Freq: 1008MHz
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
reading boot.scr
1657 bytes read in 20 ms (80.1 KiB/s)
## Executing script at 4fc00000
running boot.scr
reading uEnv.txt
967 bytes read in 20 ms (46.9 KiB/s)
reading Image
14135304 bytes read in 1240 ms (10.9 MiB/s)
reading rootfs.cpio.gz
6284224 bytes read in 566 ms (10.6 MiB/s)
reading sun50i-h5-nanopi-neo-plus2.dtb
34125 bytes read in 29 ms (1.1 MiB/s)
overlays is empty
reading overlays/sun50i-h5-fixup.scr
4109 bytes read in 35 ms (114.3 KiB/s)
## Executing script at 44500000
## Flattened Device Tree blob at 48000000
   Booting using the fdt blob at 0x48000000
   Loading Ramdisk to 49a01000, end 49fff3c0 ... OK
   reserving fdt memory region: addr=48000000 size=6e000
   Loading Device Tree to 0000000049990000, end 0000000049a00fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.111 (root@ubuntu) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #1 SMP Thu Dec 19 19:12:27 CST 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: FriendlyElec NanoPi-NEO-Plus2
[    0.000000] cma: Reserved 64 MiB at 0x000000005c000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] percpu: Embedded 21 pages/cpu @ffff80001bf70000 s46232 r8192 d31592 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129024
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait fsck.repair=yes panic=10 fbcon=map:0  data=/dev/mmcblk0p3 snd-soc-core.pmdown_time=3600000
[    0.000000] log_buf_len individual max cpu contribution: 4096 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 12288 bytes
[    0.000000] log_buf_len min size: 16384 bytes
[    0.000000] log_buf_len: 32768 bytes
[    0.000000] early log buf free: 14768(90%)
[    0.000000] PID hash table entries: 2048 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
[    0.000000] Memory: 420132K/524288K available (9278K kernel code, 748K rwdata, 3200K rodata, 512K init, 392K bss, 38620K reserved, 65536K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffff000000000000 - 0xffff000008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000   (129022 GB)
[    0.000000]       .text : 0xffff000008080000 - 0xffff000008990000   (  9280 KB)
[    0.000000]     .rodata : 0xffff000008990000 - 0xffff000008cc0000   (  3264 KB)
[    0.000000]       .init : 0xffff000008cc0000 - 0xffff000008d40000   (   512 KB)
[    0.000000]       .data : 0xffff000008d40000 - 0xffff000008dfb008   (   749 KB)
[    0.000000]        .bss : 0xffff000008dfb008 - 0xffff000008e5d020   (   393 KB)
[    0.000000]     fixed   : 0xffff7dfffe7fb000 - 0xffff7dfffec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffff7e0000000000 - 0xffff800000000000   (  2048 GB maximum)
[    0.000000]               0xffff7e0000000000 - 0xffff7e0000800000   (     8 MB actual)
[    0.000000]     memory  : 0xffff800000000000 - 0xffff800020000000   (   512 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000158] Console: colour dummy device 80x25
[    0.000186] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000196] pid_max: default: 32768 minimum: 301
[    0.000290] Security Framework initialized
[    0.000302] AppArmor: AppArmor disabled by boot time parameter
[    0.000345] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
[    0.000356] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes)
[    0.001531] ASID allocator initialised with 32768 entries
[    0.001601] Hierarchical SRCU implementation.
[    0.002001] smp: Bringing up secondary CPUs ...
[    0.003119] Detected VIPT I-cache on CPU1
[    0.003172] CPU1: Booted secondary processor [410fd034]
[    0.003930] Detected VIPT I-cache on CPU2
[    0.003955] CPU2: Booted secondary processor [410fd034]
[    0.004670] Detected VIPT I-cache on CPU3
[    0.004693] CPU3: Booted secondary processor [410fd034]
[    0.004746] smp: Brought up 1 node, 4 CPUs
[    0.004763] SMP: Total of 4 processors activated.
[    0.004770] CPU features: detected feature: 32-bit EL0 Support
[    0.004775] CPU features: detected feature: Kernel page table isolation (KPTI)
[    0.007857] CPU: All CPU(s) started at EL2
[    0.007873] alternatives: patching kernel code
[    0.008709] devtmpfs: initialized
[    0.013547] random: get_random_u32 called from bucket_table_alloc+0xf8/0x280 with crng_init=0
[    0.014152] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.014168] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.016355] pinctrl core: initialized pinctrl subsystem
[    0.017126] NET: Registered protocol family 16
[    0.017995] cpuidle: using governor menu
[    0.018710] vdso: 2 pages (1 code @ ffff000008996000, 1 data @ ffff000008d44000)
[    0.018726] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.019780] DMA: preallocated 256 KiB pool for atomic allocations
[    0.019843] Serial: AMBA PL011 UART driver
[    0.031388] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.032934] SCSI subsystem initialized
[    0.033085] usbcore: registered new interface driver usbfs
[    0.033116] usbcore: registered new interface driver hub
[    0.033161] usbcore: registered new device driver usb
[    0.033342] media: Linux media interface: v0.10
[    0.033366] Linux video capture interface: v2.00
[    0.033432] pps_core: LinuxPPS API ver. 1 registered
[    0.033437] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.033451] PTP clock support registered
[    0.033703] Advanced Linux Sound Architecture Driver Initialized.
[    0.034835] clocksource: Switched to clocksource arch_sys_counter
[    0.035063] VFS: Disk quotas dquot_6.6.0
[    0.035119] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.035228] FS-Cache: Loaded
[    0.035387] CacheFiles: Loaded
[    0.040373] NET: Registered protocol family 2
[    0.040801] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.040845] TCP bind hash table entries: 4096 (order: 4, 65536 bytes)
[    0.040939] TCP: Hash tables configured (established 4096 bind 4096)
[    0.041028] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.041047] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.041189] NET: Registered protocol family 1
[    0.041543] RPC: Registered named UNIX socket transport module.
[    0.041549] RPC: Registered udp transport module.
[    0.041553] RPC: Registered tcp transport module.
[    0.041557] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.041772] Unpacking initramfs...
[    0.309617] Freeing initrd memory: 6136K
[    0.314048] audit: initializing netlink subsys (disabled)
[    0.314176] audit: type=2000 audit(0.308:1): state=initialized audit_enabled=0 res=1
[    0.314395] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[    0.320016] FS-Cache: Netfs 'nfs' registered for caching
[    0.320389] NFS: Registering the id_resolver key type
[    0.320415] Key type id_resolver registered
[    0.320420] Key type id_legacy registered
[    0.320432] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.320438] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.325784] NET: Registered protocol family 38
[    0.325959] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.326055] io scheduler noop registered
[    0.326061] io scheduler deadline registered
[    0.326193] io scheduler cfq registered (default)
[    0.326199] io scheduler mq-deadline registered
[    0.326204] io scheduler kyber registered
[    0.326727] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO, pinctrl may not init
[    0.328386] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    0.330861] sun50i-h5-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.336877] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.337812] console [ttyS0] disabled
[    0.357944] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 32, base_baud = 1500000) is a U6_16550A
[    1.107238] console [ttyS0] enabled
[    1.133137] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 33, base_baud = 1500000) is a U6_16550A
[    1.164287] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 34, base_baud = 1500000) is a U6_16550A
[    1.193717] 1c28c00.serial: ttyS3 at MMIO 0x1c28c00 (irq = 35, base_baud = 1500000) is a U6_16550A
[    1.204715] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.211331] [drm] No driver support for vblank timestamp query.
[    1.224155] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_ops)
[    1.231619] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
[    1.239453] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops sun4i_tcon_ops)
[    1.370895] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[    1.380652] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[    1.388303] sun4i-drm display-engine: bound 1ee0000.hdmi (ops sun8i_dw_hdmi_ops)
[    1.395732] [drm] Cannot find any crtc or sizes - going 1920x1080
[    1.437383] Console: switching to colour frame buffer device 240x67
[    1.470697] sun4i-drm display-engine: fb0:  frame buffer device
[    1.476940] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    1.485625] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.495636] loop: module loaded
[    1.500483] libphy: Fixed MDIO Bus: probed
[    1.505207] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    1.511245] PPP generic driver version 2.4.2
[    1.515620] PPP BSD Compression module registered
[    1.520330] PPP Deflate Compression module registered
[    1.525420] PPP MPPE Compression module registered
[    1.530211] NET: Registered protocol family 24
[    1.534673] PPTP driver version 0.8.5
[    1.538726] usbcore: registered new interface driver qmi_wwan
[    1.544705] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.551230] ehci-platform: EHCI generic platform driver
[    1.556588] ehci-platform 1c1a000.usb: EHCI Host Controller
[    1.562174] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    1.570428] ehci-platform 1c1a000.usb: irq 14, io mem 0x01c1a000
[    1.590840] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.597533] hub 1-0:1.0: USB hub found
[    1.601322] hub 1-0:1.0: 1 port detected
[    1.605791] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.611995] ohci-platform: OHCI generic platform driver
[    1.617377] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.624003] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.631999] ohci-platform 1c1a400.usb: irq 15, io mem 0x01c1a400
[    1.699365] hub 2-0:1.0: USB hub found
[    1.703142] hub 2-0:1.0: 1 port detected
[    1.707667] usbcore: registered new interface driver cdc_acm
[    1.713331] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.721355] usbcore: registered new interface driver cdc_wdm
[    1.727035] usbcore: registered new interface driver uas
[    1.732401] usbcore: registered new interface driver usb-storage
[    1.738470] usbcore: registered new interface driver usbserial
[    1.744321] usbcore: registered new interface driver usbserial_generic
[    1.750859] usbserial: USB Serial support registered for generic
[    1.756884] usbcore: registered new interface driver option
[    1.762467] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.769521] usbcore: registered new interface driver qcserial
[    1.775282] usbserial: USB Serial support registered for Qualcomm USB modem
[    1.782801] mousedev: PS/2 mouse device common for all mice
[    1.788744] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.795534] sun6i-rtc 1f00000.rtc: RTC enabled
[    1.800023] i2c /dev entries driver
[    1.804787] lirc_dev: IR Remote Control driver registered, major 244
[    1.811144] IR NEC protocol handler initialized
[    1.815681] IR RC5(x/sz) protocol handler initialized
[    1.820732] IR RC6 protocol handler initialized
[    1.825260] IR JVC protocol handler initialized
[    1.829789] IR Sony protocol handler initialized
[    1.834403] IR SANYO protocol handler initialized
[    1.839105] IR Sharp protocol handler initialized
[    1.843807] IR MCE Keyboard/mouse protocol handler initialized
[    1.849634] IR LIRC bridge handler initialized
[    1.854076] IR XMP protocol handler initialized
[    1.858659] usbcore: registered new interface driver ati_remote
[    1.864690] usbcore: registered new interface driver imon
[    1.870121] usbcore: registered new interface driver mceusb
[    1.875721] usbcore: registered new interface driver redrat3
[    1.881422] usbcore: registered new interface driver streamzap
[    1.887339] usbcore: registered new interface driver igorplugusb
[    1.893366] usbcore: registered new interface driver iguanair
[    1.899132] usbcore: registered new interface driver ttusbir
[    1.905357] thermal thermal_zone0: failed to read out thermal zone (-16)
[    1.912399] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.920831] sdhci: Secure Digital Host Controller Interface driver
[    1.927011] sdhci: Copyright(c) Pierre Ossman
[    1.931390] Synopsys Designware Multimedia Card Interface Driver
[    1.974856] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    1.984583] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    2.040262] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.051739] mmc0: new high speed SDHC card at address b368
[    2.057682] mmcblk0: mmc0:b368 SD    15.2 GiB
[    2.064039]  mmcblk0: p1 p2 p3
[    2.234856] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    2.271216] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[    2.279662] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.282850] sunxi-mmc 1c11000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    2.288100] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.294242] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.304802] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[    2.310693] ledtrig-cpu: registered to indicate activity on CPUs
[    2.316930] hidraw: raw HID events driver (C) Jiri Kosina
[    2.322522] usbcore: registered new interface driver usbhid
[    2.328099] usbhid: USB HID core driver
[    2.338293] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[    2.344324] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    2.352841] gre: GRE over IPv4 demultiplexor driver
[    2.357744] ip_gre: GRE over IPv4 tunneling driver
[    2.363381] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.369036] NET: Registered protocol family 10
[    2.385935] Segment Routing with IPv6
[    2.389693] NET: Registered protocol family 17
[    2.394230] l2tp_core: L2TP core driver, V2.0
[    2.398595] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.403383] l2tp_netlink: L2TP netlink interface
[    2.408570] rfkill_gpio rfkill_bt: sunxi-bt device registered.
[    2.414480] 9pnet: Installing 9P2000 support
[    2.416749] random: fast init done
[    2.418798] Key type dns_resolver registered
[    2.427098] registered taskstats version 1
[    2.434547] mmc1: new high speed MMC card at address 0001
[    2.436522] Key type encrypted registered
[    2.440488] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[    2.448944] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[    2.450284] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    2.455189] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[    2.460731] dwmac-sun8i 1c30000.ethernet: Will use external PHY
[    2.472560]  mmcblk1: p1 p2 p3 p4
[    2.551592] mmc2: new high speed SDIO card at address 0001
[    2.579000] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    2.584662] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    2.591880] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    2.597537] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    2.604755] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    2.609720] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    2.617010] libphy: stmmac: probed
[    2.624520] ehci-platform 1c1b000.usb: EHCI Host Controller
[    2.630125] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[    2.638506] ehci-platform 1c1b000.usb: irq 16, io mem 0x01c1b000
[    2.658843] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    2.665490] hub 3-0:1.0: USB hub found
[    2.669266] hub 3-0:1.0: 1 port detected
[    2.673782] ehci-platform 1c1c000.usb: EHCI Host Controller
[    2.679366] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
[    2.687541] ehci-platform 1c1c000.usb: irq 18, io mem 0x01c1c000
[    2.706841] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    2.713381] hub 4-0:1.0: USB hub found
[    2.717154] hub 4-0:1.0: 1 port detected
[    2.721636] ehci-platform 1c1d000.usb: EHCI Host Controller
[    2.727222] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
[    2.735384] ehci-platform 1c1d000.usb: irq 20, io mem 0x01c1d000
[    2.754841] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    2.761379] hub 5-0:1.0: USB hub found
[    2.765152] hub 5-0:1.0: 1 port detected
[    2.769581] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    2.776207] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[    2.784230] ohci-platform 1c1b400.usb: irq 17, io mem 0x01c1b400
[    2.851326] hub 6-0:1.0: USB hub found
[    2.855100] hub 6-0:1.0: 1 port detected
[    2.859552] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    2.866176] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[    2.874234] ohci-platform 1c1c400.usb: irq 19, io mem 0x01c1c400
[    2.943286] hub 7-0:1.0: USB hub found
[    2.947059] hub 7-0:1.0: 1 port detected
[    2.951503] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    2.958127] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[    2.966162] ohci-platform 1c1d400.usb: irq 21, io mem 0x01c1d400
[    3.035300] hub 8-0:1.0: USB hub found
[    3.039073] hub 8-0:1.0: 1 port detected
[    3.043538] usb_phy_generic usb_phy_generic.3.auto: usb_phy_generic.3.auto supply vcc not found, using dummy regulator
[    3.054493] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
[    3.060244] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9
[    3.068523] hub 9-0:1.0: USB hub found
[    3.072305] hub 9-0:1.0: 1 port detected
[    3.078803] input: r-gpio-keys as /devices/platform/r-gpio-keys/input/input0
[    3.086244] ALSA device list:
[    3.089219]   #0: Dummy 1
[    3.091839]   #1: Loopback 1
[    3.094712]   #2: H3 Audio Codec
[    3.098535] Freeing unused kernel memory: 512K
Loading, please wait...
starting version 237
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... done.
mount: mounting /dev/mmcblk0p2 on /root failed: Invalid argument
Begin: Will now check userdata file system ... fsck from util-linux 2.31.1
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p3] fsck.ext4 -y -C0 /dev/mmcblk0p3
e2fsck 1.44.1 (24-Mar-2018)
ext2fs_open2: Bad magic number in super-block
fsck.ext4: Superblock invalid, trying backup blocks...
fsck.ext4: Bad magic number in super-block while trying to open /dev/mmcblk0p3
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem.  If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
    e2fsck -b 8193 <device>
 or
    e2fsck -b 32768 <device>
fsck exited with status code 8
done.
Warning: File system check failed but did not detect errors
mount: mounting /dev/mmcblk0p3 on /data failed: Invalid argument
umount: can't unmount /data: Invalid argument
Begin: Resizing ext4 file system on /dev/mmcblk0p3 ... Model: SD SD (sd/mmc)
Disk /dev/mmcblk0: 100%
Sector size (logical/physical): 512B/51[   69.262298]  mmcblk0: p1 p2 p3
2B
Partition Table: msdos
Disk Flags:
Number  Start  End    Size   Type     File system  Flags
 1      0.15%  0.79%  0.64%  primary  fat16
 2      0.79%  16.3%  15.5%  primary
 3      16.3%  100%   83.7%  primary
resize2fs 1.44.1 (24-Mar-2018)
resize2fs: Bad magic number in super-block while trying to open /dev/mmcblk0p3
Couldn't find valid filesystem superblock.
resize2fs exited with status code 1
done.
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... mount: mounting /dev on /root/dev failed: No such file or directory
done.
mount: mounting /run on /root/run failed: No such file or directory
run-init: current directory on the same filesystem as the root: error 0
Target filesystem doesn't have requested /sbin/init.
No init found. Try passing init= bootarg.
Rebooting automatically due to panic= boot argument
