maks.dav wrote: Hi. Can I use the board NanoPi NEO Air with Ethernet?
Directly not, but ypu can buy a WiFi Bridge (like Vonets) and connect the Air to the WiFi on the WiFi Bridge and on the other side of the bridge is a Ethernet-Connector....
I've successfully connected an A1277 Apple USB Ethernet Adapter (05ac:1402). It has a ASIX AX88772 chip which is supported in the standard FriendlyWrt image for the board by the `asix` kernel module. The module is not loaded automatically. To get it to work on reboot, I created a file in /etc/modules.d:
The only issue is that the combo NanoPi NEO-air + Ethernet adapter is rather power hungry when routing Wifi traffic to Ethernet. With a 2.5Amp 5v power adapter, the voltage drops to ~4.75v and the Ethernet adapter shut down sometimes. Unplug and re-plug brings it back. I need to test with a more powerful power supply.
Update: I switched to a Realtek RTL8153 Gigabit Ethernet Adapter (0bda:8153) which required no specific configuration to work. The stability issue of the asix driver seems to be unrelated to power consumption, likely an issue with the adapter itself or the `asix` kernel module (and that may be why the module is not loaded automatically).
In total there are 12 users online :: 0 registered, 0 hidden and 12 guests (based on users active over the past 5 minutes) Most users ever online was 27070 on Thu Jul 09, 2026 6:53 am
