FreeBSD 12.0-RELEASE on NanoPi-K1-Plus and NanoPi-NEO2
Hi!
I have successfully installed FreeBSD 12.0 on NanoPi-K1-Plus
U-Boot SPL 2018.09 (Nov 13 2018 - 17:08:56 +0300)
DRAM: 2048 MiB
Trying to boot from MMC1
U-Boot 2018.09 (Nov 13 2018 - 17:08:56 +0300) Allwinner Technology
CPU:   Allwinner H5 (SUN50I)
Model: FriendlyARM NanoPi K1 Plus
DRAM:  2 GiB
Loading Environment from FAT... Card did not respond to voltage select!
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
2 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
Hit any key to stop autoboot:  2  1  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found EFI removable media binary efi/boot/bootaa64.efi
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disks on usb...
Disk usb1 not ready
Disk usb2 not ready
Disk usb3 not ready
Scanning disks on mmc...
MMC Device 2 not found
MMC Device 3 not found
Found 6 disks
84296 bytes read in 8 ms (10 MiB/s)
## Starting EFI application at 40080000 ...
>> FreeBSD EFI boot block
   Loader path: /boot/loader.efi
   Initializing modules: ZFS UFS
   Load Path: /\efi\boot\bootaa64.efi
   Load Device: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/USB(0x6,0x0)/HD(1,0x01,0,0x81f,0xfff0)
   Probing 6 block devices.....+..* done
    ZFS found no pools
    UFS found 2 partitions
Consoles: EFI console
FreeBSD/arm64 EFI loader, Revision 1.1
   Command line arguments: loader.efi
   EFI version: 2.70
   EFI Firmware: Das U-Boot (rev 8216.2304)
   Console: efi (0)
   Load Device: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/USB(0x6,0x0)/HD(2,0x01,0,0x10c00,0x1cef400)
Trying ESP: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/USB(0x6,0x0)/HD(2,0x01,0,0x10c00,0x1cef400)
Setting currdev to disk1p2:
Loading /boot/defaults/loader.conf
Loading Kernel and Modules (Ctrl-C to Abort)
boot/kernel/kernel text=0x7110fc data=0x142fc0+0x79840c syms=[0x8+0xed6c0+0x8+0xe5645]
boot/entropy size=0x1000
boot/dtb/sun50i-h5-nanopi-k1-plus.dtb size=0x602e
boot/kernel/fuse.ko text=0x4850 text=0x82f0 data=0x101e0+0xfe88 syms=[0x8+0x2658+0x8+0x1a9c]
Hit [Enter] to boot immediately, or any other key for command prompt.
Booting [/boot/kernel/kernel]...
Using DTB from loaded file '/boot/dtb/sun50i-h5-nanopi-k1-plus.dtb'.
EHCI failed to shut down host controller.
---<<BOOT>>---
Copyright (c) 1992-2018 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
   The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 12.0-PRERELEASE #0 r340474M: Fri Nov 16 09:14:22 MSK 2018
    root@nanopi-k1-plus:/usr/src/sys/arm64/compile/NANOPI arm64
FreeBSD clang version 6.0.1 (tags/RELEASE_601/final 335540) (based on LLVM 6.0.1)
VT: init without driver.
Starting CPU 1 (1)
Starting CPU 2 (2)
Starting CPU 3 (3)
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
random: unblocking device.
random: entropy device external interface
MAP 47ffe000 mode 2 pages 2
MAP 48005000 mode 2 pages 2
MAP b8f1d000 mode 2 pages 1
MAP b8f22000 mode 2 pages 1
MAP bdf49000 mode 2 pages 1
kbd0 at kbdmux0
ofwbus0: <Open Firmware Device Tree>
ofw_clkbus0: <OFW clocks bus> on ofwbus0
clk_fixed0: <Fixed clock> on ofw_clkbus0
clk_fixed1: <Fixed clock> on ofw_clkbus0
clk_fixed2: <Fixed clock> on ofw_clkbus0
simplebus0: <Flattened device tree simple bus> on ofwbus0
ccu_h3ng0: <Allwinner H3/H5 Clock Control Unit NG> mem 0x1c20000-0x1c203ff on simplebus0
regfix0: <Fixed Regulator> on ofwbus0
regfix1: <Fixed Regulator> on ofwbus0
regfix2: <Fixed Regulator> on ofwbus0
ccu_sun8i_r0: <Allwinner SUN8I_R Clock Control Unit NG> mem 0x1f01400-0x1f014ff on simplebus0
psci0: <ARM Power State Co-ordination Interface Driver> on ofwbus0
aw_sid0: <Allwinner Secure ID Controller> mem 0x1c14000-0x1c143ff on simplebus0
gic0: <ARM Generic Interrupt Controller> mem 0x1c81000-0x1c81fff,0x1c82000-0x1c83fff,0x1c84000-0x1c85fff,0x1c86000-0x1c87fff irq 38 on simplebus0
gic0: pn 0x2, arch 0x2, rev 0x1, implementer 0x43b irqs 224
gpio0: <Allwinner GPIO/Pinmux controller> mem 0x1c20800-0x1c20bff irq 18,19,20 on simplebus0
gpiobus0: <OFW GPIO bus> on gpio0
gpio1: <Allwinner GPIO/Pinmux controller> mem 0x1f02c00-0x1f02fff irq 44 on simplebus0
gpiobus1: <OFW GPIO bus> on gpio1
gpioregulator0: <GPIO controlled regulator> on ofwbus0
rtc0: <Allwinner RTC> mem 0x1f00000-0x1f00053 irq 40,41 on simplebus0
rtc0: registered as a time-of-day clock, resolution 1.000000s
generic_timer0: <ARMv8 Generic Timer> irq 0,1,2,3 on ofwbus0
Timecounter "ARM MPCore Timecounter" frequency 24000000 Hz quality 1000
Event timer "ARM MPCore Eventtimer" frequency 24000000 Hz quality 1000
aw_syscon0: <Allwinner syscon> mem 0x1c00000-0x1c00fff on simplebus0
awusbphy0: <Allwinner USB PHY> mem 0x1c19400-0x1c1942b,0x1c1a800-0x1c1a803,0x1c1b800-0x1c1b803,0x1c1c800-0x1c1c803,0x1c1d800-0x1c1d803 on simplebus0
aw_mmc0: <Allwinner Integrated MMC/SD controller> mem 0x1c0f000-0x1c0ffff irq 6 on simplebus0
mmc0: <MMC/SD bus> on aw_mmc0
aw_mmc1: <Allwinner Integrated MMC/SD controller> mem 0x1c10000-0x1c10fff irq 7 on simplebus0
mmc1: <MMC/SD bus> on aw_mmc1
aw_mmc2: <Allwinner Integrated MMC/SD controller> mem 0x1c11000-0x1c11fff irq 8 on simplebus0
mmc2: <MMC/SD bus> on aw_mmc2
ehci0: <Allwinner Integrated USB 2.0 controller> mem 0x1c1a000-0x1c1a0ff irq 10 on simplebus0
usbus0: EHCI version 1.0
usbus0 on ehci0
ohci0: <Generic OHCI Controller> mem 0x1c1a400-0x1c1a4ff irq 11 on simplebus0
usbus1 on ohci0
ehci1: <Allwinner Integrated USB 2.0 controller> mem 0x1c1b000-0x1c1b0ff irq 12 on simplebus0
usbus2: EHCI version 1.0
usbus2 on ehci1
ohci1: <Generic OHCI Controller> mem 0x1c1b400-0x1c1b4ff irq 13 on simplebus0
usbus3 on ohci1
ehci2: <Allwinner Integrated USB 2.0 controller> mem 0x1c1c000-0x1c1c0ff irq 14 on simplebus0
usbus4: EHCI version 1.0
usbus4 on ehci2
ohci2: <Generic OHCI Controller> mem 0x1c1c400-0x1c1c4ff irq 15 on simplebus0
usbus5 on ohci2
ehci3: <Allwinner Integrated USB 2.0 controller> mem 0x1c1d000-0x1c1d0ff irq 16 on simplebus0
usbus6: EHCI version 1.0
usbus6 on ehci3
ohci3: <Generic OHCI Controller> mem 0x1c1d400-0x1c1d4ff irq 17 on simplebus0
usbus7 on ohci3
gpioc0: <GPIO controller> on gpio0
awg0: <Allwinner Gigabit Ethernet> mem 0x1c30000-0x1c3ffff irq 23 on simplebus0
miibus0: <MII bus> on awg0
rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 0 on miibus0
rgephy0:  none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
rgephy1: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 7 on miibus0
rgephy1:  none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
awg0: Ethernet address: 02:82:8e:06:38:08
aw_wdog0: <Allwinner A31 Watchdog> mem 0x1c20ca0-0x1c20cbf irq 26 on simplebus0
uart0: <16750 or compatible> mem 0x1c28000-0x1c283ff irq 31 on simplebus0uart0: console (115384,n,8,1)
aw_ir0: <Allwinner CIR controller> mem 0x1f02000-0x1f0203f irq 42 on simplebus0
gpioc1: <GPIO controller> on gpio1
aw_thermal0: <Allwinner Thermal Sensor Controller> mem 0x1c25000-0x1c250ff irq 45 on simplebus0
cpulist0: <Open Firmware CPU Group> on ofwbus0
cpu0: <Open Firmware CPU> on cpulist0
cpufreq_dt0: <Generic cpufreq driver> on cpu0
cpu1: <Open Firmware CPU> on cpulist0
cpu2: <Open Firmware CPU> on cpulist0
cpu3: <Open Firmware CPU> on cpulist0
gpioled0: <GPIO LEDs> on ofwbus0
cryptosoft0: <software crypto>
fuse-freebsd: version 0.4.4, FUSE ABI 7.8
Timecounters tick every 1.000 msec
usbus0: 480Mbps High Speed USB v2.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 480Mbps High Speed USB v2.0
usbus3: 12Mbps Full Speed USB v1.0
usbus4: 480Mbps High Speed USB v2.0
ugen0.1: <Allwinner EHCI root HUB> at usbus0
uhub0: <Allwinner EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ugen1.1: <Generic OHCI root HUB> at usbus1
uhub1: <Generic OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <Allwinner EHCI root HUB> at usbus2
uhub2: <Allwinner EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
ugen4.1: <Allwinner EHCI root HUB> at usbus4
uhub3: <Allwinner EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus4
ugen3.1: <Generic OHCI root HUB> at usbus3
uhub4: <Generic OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
usbus5: 12Mbps Full Speed USB v1.0
usbus6: 480Mbps High Speed USB v2.0
usbus7: 12Mbps Full Speed USB v1.0
ugen5.1: <Generic OHCI root HUB> at usbus5
uhub5: <Generic OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus5
ugen6.1: <Allwinner EHCI root HUB> at usbus6
uhub6: <Allwinner EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus6
ugen7.1: <Generic OHCI root HUB> at usbus7
uhub7: <Generic OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus7
mmcsd0: 16GB <SDHC SD16G 3.0 SN 002CF127 MFG 10/2017 by 65 42> at mmc0 50.0MHz/4bit/32768-block
mmc0: Failed to set VCCQ for card at relative address 7
mmc1: No compatible cards found on bus
aw_mmc1: Spurious interrupt - no active request, rint: 0x00000004
AW_MMC_INT_RESP_TIMEOUT
uhub1: 1 port with 1 removable, self powered
mmc2: No compatible cards found on bus
aw_mmc2: Spurious interrupt - no active request, rint: 0x00000004
Release APs...done
Trying to mount root from ufs:/dev/mmcsd0s2a [rw,noatime]...
CPU  0: ARM Cortex-A53 r0p4 affinity:  0
 Instruction Set Attributes 0 = <AES+PMULL,SHA1,SHA2,CRC32>
 Instruction Set Attributes 1 = <>
         Processor Features 0 = <AdvSIMD,Float,EL3 32,EL2 32,EL1 32,EL0 32>
         Processor Features 1 = <0>
      Memory Model Features 0 = <4k Granule,64k Granule,MixedEndian,S/NS Mem,16bit ASID,1TB PA>
      Memory Model Features 1 = <>
      Memory Model Features 2 = <32b CCIDX,48b VA>
             Debug Features 0 = <2 CTX Breakpoints,4 Watchpoints,6 Breakpoints,PMUv3,Debug v8>
             Debug Features 1 = <0>
         Auxiliary Features 0 = <0>
         Auxiliary Features 1 = <0>
CPU  1: ARM Cortex-A53 r0p4 affinity:  1
CPU  2: ARM Cortex-A53 r0p4 affinity:  2
CPU  3: ARM Cortex-A53 r0p4 affinity:  3
uhub4: 1 port with 1 removable, self powered
uhub5: 1 port with 1 removable, self powered
uhub7: 1 port with 1 removable, self powered
uhub0: 1 port with 1 removable, self powered
uhub2: 1 port with 1 removable, self powered
uhub3: 1 port with 1 removable, self powered
uhub6: 1 port with 1 removable, self powered
Setting hostuuid: 30383238-3030-3130-3035-656630383330.
Setting hostid: 0x2b98f89c.
Starting file system checks:
/dev/mmcsd0s2a: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/mmcsd0s2a: clean, 141289 free (977 frags, 17539 blocks, 0.4% fragmentation)
/dev/mmcsd0s2d: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/mmcsd0s2d: clean, 2266940 free (948 frags, 283249 blocks, 0.0% fragmentation)
Mounting local filesystems:ugen2.2: <Cypress Semiconductor IDSZIVU2.1> at usbus2
umass0 on uhub2
umass0: <Cypress Semiconductor IDSZIVU2.1, class 0/0, rev 2.00/0.01, addr 2> on usbus2
da0 at umass-sim0 bus 0 scbus0 target 0 lun 0
da0: <FUJITSU MHT2040AT 00> Fixed Direct Access SCSI device
da0: Serial Number ABCD048FA875
da0: 40.000MB/s transfers
da0: 38154MB (78140160 512 byte sectors)
da0: quirks=0x2<NO_6_BYTE>
ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib /usr/local/lib/perl5/5.26/mach/CORE /usr/local/lib/samba4
Setting hostname: nanopi-k1-plus.
Setting up harvesting: [UMA],[FS_ATIME],SWI,INTERRUPT,NET_NG,NET_ETHER,NET_TUN,MOUSE,KEYBOARD,ATTACH,CACHED
Feeding entropy: .
lo0: link state changed to UP
awg0: link state changed to DOWN
Starting Network: lo0 awg0.
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
   options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
   inet 127.0.0.1 netmask 0xff000000
   groups: lo
awg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
   options=8000b<RXCSUM,TXCSUM,VLAN_MTU,LINKSTATE>
   ether 02:82:8e:06:38:08
   media: Ethernet autoselect (none)
   status: no carrier
Starting devd.
awg0: link state changed to UP
Starting dhclient.
DHCPREQUEST on awg0 to 255.255.255.255 port 67
ip length 350 disagrees with bytes received 354.
accepting packet with data after udp payload.
DHCPACK from 10.15.0.11
bound to 10.15.0.151 -- renewal in 86400 seconds.
add host 127.0.0.1: gateway lo0 fib 0: route already in table
Waiting 1s for the default route interface:
Creating and/or trimming log files.
Starting syslogd.
No core dumps found.
Clearing /tmp (X related).
Starting local daemons:.
Updating motd:.
Mounting late filesystems:.
Starting powerd.
Performing sanity check on sshd configuration.
Starting sshd.
Starting cron.
Starting bsnmpd.
Starting background file system checks in 60 seconds.
Fri Nov 16 15:20
FreeBSD/arm64 (nanopi-k1-plus) (ttyu0)
login: root
Nov 16 15:20:12 nanopi-k1-plus login[826]: ROOT LOGIN (root) ON ttyu0
FreeBSD 12.0-PRERELEASE (NANOPI) #0 r340474M: Fri Nov 16 09:14:22 MSK 2018
                        Welcome to FreeBSD!
Release Notes, Errata: https://www.FreeBSD.org/releases/
Security Advisories:   https://www.FreeBSD.org/security/
FreeBSD Handbook:      https://www.FreeBSD.org/handbook/
FreeBSD FAQ:           https://www.FreeBSD.org/faq/
Questions List: https://lists.FreeBSD.org/mailman/listinfo/freebsd-questions/
FreeBSD Forums:        https://forums.FreeBSD.org/
Documents installed with the system are in the /usr/local/share/doc/freebsd/
directory, or can be installed later with:  pkg install en-freebsd-doc
For other languages, replace "en" with a language code like de or fr.
Show the version of FreeBSD installed:  freebsd-version ; uname -a
Please include that output and any error messages when posting questions.
Introduction to manual pages:  man man
FreeBSD directory layout:      man hier
Edit /etc/motd to change this login announcement.
root@nanopi-k1-plus:~ #
root@nanopi-k1-plus:~ # uname -a
FreeBSD nanopi-k1-plus 12.0-PRERELEASE FreeBSD 12.0-PRERELEASE #0 r340474M: Fri Nov 16 09:14:22 MSK 2018     root@nanopi-k1-plus:/usr/src/sys/arm64/compile/NANOPI  arm64
root@nanopi-k1-plus:~ # ls -lsa /
total 97
4 drwxr-xr-x  20 root  wheel      512 Nov 16 15:19 .
4 drwxr-xr-x  20 root  wheel      512 Nov 16 15:19 ..
4 -rw-r--r--   2 root  wheel     1057 Nov 15 21:56 .cshrc
4 -rw-r--r--   2 root  wheel      249 Nov 15 21:56 .profile
4 drwxrwxr-x   2 root  operator   512 Nov 15 21:56 .snap
4 drwxr-xr-x   2 root  wheel     1024 Nov 15 21:56 bin
4 drwxr-xr-x  11 root  wheel     1024 Nov 16 10:42 boot
8 -r--r--r--   1 root  wheel     6175 Nov 15 21:56 COPYRIGHT
1 dr-xr-xr-x  12 root  wheel      512 Nov 16 18:19 dev
4 -rw-------   1 root  wheel     4096 Nov 16 15:19 entropy
4 drwxr-xr-x  25 root  wheel     2560 Nov 15 21:56 etc
4 drwxr-xr-x   4 root  wheel     1536 Nov 15 21:56 lib
4 drwxr-xr-x   3 root  wheel      512 Nov 15 21:56 libexec
4 drwx------   2 root  wheel      512 Nov 15 21:56 lost+found
4 drwxr-xr-x   2 root  wheel      512 Nov 15 21:56 media
4 drwxr-xr-x   2 root  wheel      512 Nov 15 21:56 mnt
4 drwxr-xr-x   2 root  wheel      512 Nov 15 21:56 net
4 dr-xr-xr-x   2 root  wheel      512 Nov 15 21:56 proc
4 drwxr-xr-x   2 root  wheel      512 Nov 15 21:56 rescue
4 drwxr-xr-x   7 root  wheel      512 Nov 16 10:40 root
4 drwxr-xr-x   2 root  wheel     2560 Nov 15 21:56 sbin
4 drwxrwxrwt   7 root  wheel      512 Nov 16 15:20 tmp
4 drwxr-xr-x  16 root  wheel      512 Nov 15 21:56 usr
4 drwxr-xr-x  26 root  wheel      512 Nov 16 18:19 var
SleepWalker wrote:
Hi!
Nice job. Big thumbs up.
NicoD wrote:
SleepWalker wrote:
Hi!
It was easy
Hello to ALL!
I successfully installed FreeBSD 12.0-RELEASE on NanoPi-K1-Plus and NanoPi-NEO2.
Checking the assembly was carried out using the native compilation of WORLD and KERNEL on the NanoPi-K1-Plus.
Logs are attached.
>>> World build started on Mon Dec 10 14:42:42 MSK 2018
>>> Rebuilding the temporary build tree
>>> stage 1.1: legacy release compatibility shims
>>> stage 1.2: bootstrap tools
>>> stage 2.3: build tools
>>> stage 3: cross tools
>>> stage 3.1: recording build metadata
>>> stage 4.1: building includes
>>> stage 4.2: building libraries
>>> stage 4.3: building everything
>>> World build completed on Mon Dec 10 15:31:09 MSK 2018
>>> Kernel build for NANOPI started on Mon Dec 10 15:33:09 MSK 2018
>>> stage 1: configuring the kernel
>>> stage 3.1: building everything
>>> Kernel build for NANOPI completed on Mon Dec 10 15:36:14 MSK 2018
>>> Install check world
>>> Making hierarchy
>>> Installing everything started on Mon Dec 10 15:38:19 MSK 2018
>>> Installing everything completed on Mon Dec 10 15:46:06 MSK 2018
>>> Install check kernel
>>> Installing kernel NANOPI on Mon Dec 10 15:49:30 MSK 2018
>>> Installing kernel NANOPI completed on Mon Dec 10 15:50:36 MSK 2018
To download and use links.
https://drive.google.com/open?id=17L3P6fUvIlHGXBCrO7xqhmYqcqHOHBt6
https://drive.google.com/open?id=1O-OYasT_44VI35R_0ho6aIKhTqVUUyLf
Use SSH to Login.
Login: admin
Password: admin
admin@nanopi-k1-plus:~ % uname -a
FreeBSD nanopi-k1-plus 12.0-RELEASE FreeBSD 12.0-RELEASE #1 r341703M: Mon Dec 10 15:33:53 MSK 2018     root@nanopi-k1-plus.kubsu.ru:/usr/obj/usr/src/arm64.aarch64/sys/NANOPI  arm64
admin@nanopi-k1-plus:~ % su - root
I wish you success!
In total there are 44 users online :: 0 registered, 0 hidden and 44 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 44 guests
