Nano PI NEO / NEO2 + 2'8 TFT enclosure
i have made a quality Nano PI NEO / NEO2 + 2'8 Matrix TFT enclosure, it is available here :
https://pinshape.com/items/46665-3d-pri ... -enclosure
There are 2 parts, 2mm thick walls, optimized for 3D printing, no screws, accessible push button and it look like an old TV. :) (i will make some pictures of the real thing soon)
There is two variations for both parts for the first revision (top & bottom) :
    Enclosure with ETH hole or without (you can hide a USB WIFI key inside, that is how i am using it)
    Top part optionally fully covering the push button
There is also two type of revisions :
    Rev 4 bottom and Rev 3 top are compatible, they do not cover parts of the screen entirely (so you can see the screen border), the enclosure is also 1mm thicker than the next revision
    Rev 5, the top cover all the screen parts (and push button) with 0.4mm part so it look great and finished, 1mm was removed from the top wall and 1mm was added to the top band to remove some light bending issue when the display is inserted
I print them with PETG and use it on my desk as a monitoring system for my 3D printer.
Updated the design to Rev 5, the top part now cover all the screen parts so it look great and finished, with some painting this could look like a final product like a mini TV box or industrial monitoring screen or something, i have also fixed some slight bending issues on the top wall and top band (as pictured in the photos).
Here is a photo of it (note : this is between Rev 4 and 5, the top now cover the push button as well and the top band is now slightly larger to remove the bending issue) :
