Developing FriendlyCore
I'm looking for some tips for development with FriendlyCore for the NanoPi NEO Core2-LTS. I don't have too much experience deploying embedded Linux, so my very basic (and rather generic) question is: what should my workflow be? How do I cross-compile custom applications for the processor on my (Ubuntu 16.04) machine? How do I create a full image that I can flash to the board? I read and followed the "Mainline U-boot and Linux" wiki, but it only tells me how to compile those components, not how to develop my own applications. I read the FriendlyCore wiki also, but it too doesn't seem to address my question, it's more of a documentation of the distro's features.
Thanks.
Thanks.
Perhaps try community development engine. It is more user-friendly and it supports most of FriendlyElec boards:
https://docs.armbian.com/Developer-Guid ... eparation/
Thanks, Igor. I was able to build an Armbian image, but my (again, generic) question still stands. If I want to develop, build and test my custom apps not on the target hardware, but on my development machine, how do I go about the development process? How do I include my apps in the image?
ptz wrote:
Armbain is more or less plain Debian/Ubuntu so you can do all application testing in x86 virtual machines (I also do that way). When you are done, use this: https://docs.armbian.com/Developer-Guid ... ion-script
There is also one working example for a complex build - Openmediavault, which uses our base by default.
I see.
And if my board were supported (which it isn't) in yocto/buildroot, I would also have that option, right? New to embedded Linux, as I said.
I see.
I'm using yocto for Nanopi development ; support for buildroot may exist too for Nanopi.
As explained by igorp, I started with ubuntu or armbian distribution on nanopi. Since I need to modify three or more components provided by the distribution (kernel config, audio subsystem replacement, boot order), I first started to tune the armbian/ubuntu distribution generation, but yocto is more scalable for the needs of my project. You can find my (somewhat complex) project at https://github.com/auto3000/pedalpi-dev-platform.
In general.Yocto or Buildroot are different, more complex build engines. You will need to invest a lot more time to get going ... Armbian is good for most general purpose cases, where you don't need deep control over packages/subsystems.
It really depends on your specifics needs.
Yes, you are right, I realize now that there is both yocto and buildroot support. I was erroneously under the impression that the board I was using (nanopi neo core2) was somehow different than the supported nanopi neo2, and now realized it was not. Thanks for the link.
Thanks, I'll need to think about it. At least one thing points in the direction of yocto - I need a robust OTA update client, and a few of those I looked at integrate easily into a yocto build.
