NanoPI NEO Uarts Showing Garbage
I have NaoPI Neo, just opened it out of the box yesterday and was testing the uarts.
I'm hooked to pins 6 (gnd), 8 (tx) and 10 (rx), running to my PC's pin's 2/3/5 (9-pin serial port).
My serial port is setup as:
# root@NovusOne:~# stty -F /dev/ttyS1
speed 9600 baud; line = 0;
I'm running Putty on my computer, serial port is set to 9600/8/N/1.
On the Nano, I do a simple:
# cat /dev/ttyS1
Which dumps out whatever shows up at the com port. On the Putty, I dump a small text file (I'm lazy). I get garbage.
# cat /dev/ttyS1
5�Wy_�_=9)��Y5�����g5#����囋�_!
��g!9='��}!�;5�=/5�!
%;/5�m_�=9)�����7���s'=1����Wy_�_!9)��Y5�����}9)�����g5#���噋�g!9='��_!
5�Ya9)�g=
5#�9!%��#���y!##-!#��y'!5��#�廡�#��嗋���}5=�!!�%=#
It's consistent at any baud rate with any bit/parity setting. I was unable to get ttyS0 to work at all [no response]. Device Tree file has been untouched. An interesting effect is I get the same pattern of garbage if I continue to repeat the paste operation. So, that tells me it's some kind of configuration.
Anyone have any idea what is going on?! Is my nanopi broke?
UPDATE:
I ran minicom on the port instead of doing a "cat /dev/ttyS2". Minicom is spewing out garbage as well. I played with all the parity and stop bit settings.. no luck. I even checked my cable for continuity and connections... all is fine.
Anyone have any clues?
And the baud rate? Try 115200
Okay, from what I can tell the Nano is bit flipping every bit. All 1's are turned to 0 and vise versa. Is there some kind of Linux setting to do this? (I've never heard of it)
Had to Google <serial port inverted> seems a few people have had this issue.
However, I went back and re-read your original post ... specifically about how you are wiring these two units. As far as I am aware a DB9 connector on a PC is a real RS-232 item, ie voltage levels like +/-15 Volts and you can not just wire them up to a UART running probably 3V.
So, do you have something between thee two units to provide a proper voltage interface?
https://www.raspberrypi.org/forums/viewtopic.php?f=44&t=22258
Maybe, this sheds light on the potential problem space.
For DB9 to the NanoPi serial Port you need a TTL-Levelshifter and 115.200 Baud
Thanks for the heads up! I didn't realize I need a voltage leveler. Is there any place I can readily pick up one?
FriendlyArm's PSU-ONECOM
Good chance your NEO's UART has been damaged.
http://www.friendlyarm.com/index.php?ro ... duct_id=89
In total there are 70 users online :: 0 registered, 0 hidden and 70 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 70 guests
