Missing shared object libfahw.so in matrix git
Hello. I previously used matrix github on nanopi neo for infra red purposes.
On nanopi neo air i would like to do the same. But it seems the matrix git has changed and now the shared object most of the examples rely on is missing. Libfahw.so. Could you please update the matrix git and provide the missing file?
Thanks.
Found the problem. I forgot the final step: make install, which creates and puts the shared objects in the right places.
Thanks.
Hi ,
The Air now have not supported the matrix starter kit , if you want to use them ,you can refer to the NEO's codes.
thank you!
