Getting Max2Play to work on it with the Matrix - NanoHat PCM
I got the Matrix - NanoHat PCM5102A for my NanoPi NEO Air. Installed Max2play on it and I can go to it's web page but can't start the player.
I can play a mp3 on the command line and it works looks like this:
root@air:~# madplay /media/Nintendo\ -\ Dire\,\ Dire\ Docks.mp3
MPEG Audio Decoder 0.15.2 (beta) - Copyright (C) 2000-2004 Robert Leslie et al.
Title: Dire, Dire Docks
Artist: Nintendo
Album: Super Mario 64
Track: 9
Genre: Soundtrack
7126 frames decoded (0:03:06.1), -0.8 dB peak amplitude, 0 clipped samples
root@air:~#
This my help in the debug of the Max2play is shows this:
#### SQUEEZELITE VERSION ####
Squeezelite v1.8.6-830, Copyright 2012-2015 Adrian Smith, 2015-2017 Ralph Irving.
#### SQUEEZELITE BUILDOPTIONS ####
Build options: LINUX ALSA EVENTFD RESAMPLE FFMPEG VISEXPORT DSD
#### AUDIOPLAYER CONFIG ####
### Configuration of Audioplayers
SQUEEZELITE_PARAMETER=-o dmix:CARD=sndhdmi,DEV=0 -a 80:4:: madplay
SQUEEZESLAVE_PARAMETER=-n plugequal
SHAIRPORT_PARAMETER=-d plughw:CARD=sndhdmi,DEV=0
USE_USB_DAC=0
USE_EQUALIZER=0
#### SQUEEZELITE -l ####
Output devices:
  null                           - Discard all samples (playback) or generate zero samples (capture)
  sysdefault:CARD=Pcm5102a       - Pcm5102a,  - Default Audio Device
  dmix:CARD=Pcm5102a,DEV=0       - Pcm5102a,  - Direct sample mixing device
  dsnoop:CARD=Pcm5102a,DEV=0     - Pcm5102a,  - Direct sample snooping device
  hw:CARD=Pcm5102a,DEV=0         - Pcm5102a,  - Direct hardware device without any conversions
  plughw:CARD=Pcm5102a,DEV=0     - Pcm5102a,  - Hardware device with all software conversions
  sysdefault:CARD=sndhdmi        - sndhdmi,  - Default Audio Device
  dmix:CARD=sndhdmi,DEV=0        - sndhdmi,  - Direct sample mixing device
  dsnoop:CARD=sndhdmi,DEV=0      - sndhdmi,  - Direct sample snooping device
  hw:CARD=sndhdmi,DEV=0          - sndhdmi,  - Direct hardware device without any conversions
  plughw:CARD=sndhdmi,DEV=0      - sndhdmi,  - Hardware device with all software conversions
#### SHAIRPORT VERSION ####
2.8.6-OpenSSL-Avahi-ALSA-soxr-sysconfdir:/usr/local/etc
#### OUTPUT SOUND DETAILS CARD 0 ####
access: MMAP_INTERLEAVED
format: S32_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 4410
buffer_size: 22050
#### OUTPUT SOUND DETAILS CARD 1 ####
closed
I got this screen shot here and that my help to know what is wrong. It's here.
-Raymond Day
I got it working!
Just had to do a:
apt install squeezelite
Then on the Max2Play under Audioplayer it said:
Status: Squeezelite is running with processID 10006
I am playing songs now though the NanoHat PCM5102A card now. It's working real good.
This on on the nanopi neo air.
Wow took a long time no one else could help!
-Raymond Day
Raymond Day wrote:
I got it working!
Just had to do a:
-Raymond Day
Nice work, Where do i find the max2play installer? Just see the SD card image on the website
I think I got it at this link.
But looks like it's been updated from when I downloaded it. My download file is named nanopi-air-core-qte-sd4g-20161213.img.zip but now at that link they have nanopi-neo-ubuntu-core-gte-sd4g-20170220.img.zip I guess it's updated more. When I did a apt get update it did a lot on mine.
Did this a wile ago now. Mines been running real good with Max2Play and the audio hat.
O the max2play installer.
I ported here
Easy to do. I have not tested this out on a new install yet. But I am all most sure it will work.
-Raymond Day
