How to enter FEL-Mode over MicroUSB in NanoPi NEO Core
Hi all,
I've read a lot of postings in this and other forums so far - but didn't found a solution.
According the schematic of the NEO Core it seems that the Pin to enable the FEL-Mode in H3 is fixed pull-up to Vcc. But what does it mean, is it always enabled or disabled?
I want to flash the eMMC via USB-Cable, without the need of inserting an SD-Card (due to installation of multiple NanoPis).
So: How to bring the NanoPi NEO Core into FEL-Mode to flash the eMMC?
Achim
Nobody ever used FEL-Mode on NEO Core????
Actually, I have! I’ve used FEL-Mode on NEO Core a couple of times for debugging and flashing custom firmware. It can be a bit tricky if you’re not familiar with the process, but it’s definitely useful in certain situations. Are you running into any issues with it?
In total there are 41 users online :: 0 registered, 0 hidden and 41 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 41 guests
