'Display Debian GUI on 2.8"LCD' does not work on M1, why?
Nanopi status LCD program works fine:
http://wiki.friendlyarm.com/wiki/index.php/Matrix_-_2%278_SPI_Key_TFT#Compile_.26_Run_Test_Program
But 'Display Debian GUI on 2.8"LCD' does not work on my M1:
http://wiki.friendlyarm.com/wiki/index.php/Matrix_-_2%278_SPI_Key_TFT#Display_Debian_GUI_on_2.8.22LCD
Likely because of the ioctl error logged, what does that mean, or how to prevent?
Last login: Sat Nov 19 04:58:09 2016 from oc7888421160.fritz.box
root@NanoPi-M1:~# cd matrix/demo/nanopi-status/
root@NanoPi-M1:~/matrix/demo/nanopi-status# ./display-debian.sh /dev/fb-st7789s
-bash: ./display-debian.sh: Permission denied
root@NanoPi-M1:~/matrix/demo/nanopi-status# chmod 755 display-debian.sh
Hardware:sun8i
Revision:0000
root@NanoPi-M1:~/matrix/demo/nanopi-status# dmesg | tail -14
[  323.054008] EXT4-fs (mmcblk0p2): last error at 1479486542: ext4_remount:4398: inode 744
[  338.033580] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
[  338.045341] fbtft_device:  SPI devices registered:
[  338.050705] fbtft_device:      spidev spi0.0 33000kHz 8 bits mode=0x00
[  338.057947] fbtft_device:  'fb' Platform devices registered:
[  338.477419] graphics fb8: fb_st7789s frame buffer, 240x320, 150 KiB video memory, 16 KiB DMA buffer memory, fps=30, spi0.2 at 25 MHz
[  338.490717] fbtft_device:  GPIOS used by 'matrix-st7789s':
[  338.496804] fbtft_device:    'dc' = GPIO1
[  338.501285] fbtft_device:    'reset' = GPIO203
[  338.506211] fbtft_device:    'cs' = GPIO67
[  338.510766] fbtft_device:  SPI devices registered:
[  338.516081] fbtft_device:      spidev spi0.0 33000kHz 8 bits mode=0x00
[  338.523338] fbtft_device:      fb_st7789s spi0.2 25000kHz 8 bits mode=0x00
[  339.109446] [DISP] disp_ioctl,line:1584:para err in disp_ioctl, cmd = 0x0,screen id = 65536
Hermann.
Do you need to fix the Permission denied, near the beginning?
I did that in 2nd line, and execution in 3rd line was without permission denied, but did not work (black screen) ...
Hermann.
Oops :(
Now just debian system supports the matrix hardware,what system did you use? You can clone the matrix code on the board,and execute the following commands on the board :
$ apt-get update && apt-get install git
$ git clone https://github.com/friendlyarm/matrix.git
Compile and install Matrix:
$cd matrix/demo/nanopi-status
$./build.sh
$./run.sh /dev/fb-st7789s
Boot your ARM board with Debian and and launch the Debian GUI by running the following commands:
$ cd matrix/demo/nanopi-status/
$ ./display-debian.sh /dev/fb-st7789s
Hi!
I have exactly the same problem with the M1. (I verified this with 2 separate boards and displays)
I've tried this with an older debian image and the newest one and I get the same result as you every time.
My display works perfectly fine with the status script but the display-debian script doesn't work at all (very disappointing since this is what I purchased the board for :evil: ).
The display lights up white for a second when you start the script and the switches to black and does nothing.
I followed the steps outlined on the wiki page to start the script
In total there are 42 users online :: 0 registered, 0 hidden and 42 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 42 guests
